Results 1 to 5 of 5
Thread: Mira engine warning light?
    vtecyo's Avatar
    Oct 2012
    334
    5 Post(s)
    Default Mira engine warning light?
    So i have a Mira CVT and today coming back to Lahore the engine symbol on the display started to illuminate, what could be the reason?
    vtecyo's Avatar
    Oct 2012
    334
    5 Post(s)
    bump.....
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by vtecyo View Post
    bump.....
    is she on CNG??
    disconnect the Battery -ve terminal for 10mins & then reconnect it, if it appears again then take it to workshop for diagnosis test
    sheazi's Avatar
    Jun 2009
    24
    319
    3 Post(s)
    dc the battery terminal...wait for some time ...... the ecu restarts on connecting the terminal again...if light shows again go to workshop..also chk all the fuses
    ch.talal's Avatar
    Mar 2014
    663
    19 Post(s)
    Quote Originally Posted by sheazi View Post
    He must have done something about the problem in past one year. By the way, I am also considering Masters degree in Forums mining business.
