Results 1 to 10 of 10
Thread: Cuore ka 'goda' bar bar toot jata he
    nabeelkhan's Avatar
    Oct 2008
    86
    516
    9 Post(s)
    Default Cuore ka 'goda' bar bar toot jata he
    There is something called 'goda' (Punjabi wala) beneath cars. I am not sure what is proper English word for it. meri Cuore ka 'goda' koi 3-4 dafa toot chuka he in last 6 months. what could be the reason ?
    This time there is noise in the front left wheel when I rotate my car fully.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    are you buying locally rebuilt ones.
    btw they are called CV joint or axle.
    Driver41's Avatar
    Apr 2012
    279
    3 Post(s)
    Crown lifan is now offering inners and outers with 6 months warranty. Seems good. Recently i had my outer cv joints installed in khyber. 3 months, no prob yet..
    And many people fall in trap of repairing of joints which is sheer waste of money and time, seems like case of OP.
    mfniazi's Avatar
    Jul 2008
    33
    119
    Some people that I know call ball joints as goda.
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    i faced that issue with my accidented Corolla repeatedly every six months, many times. Later when i discussed this, an old member Jag asked if the engine's foundations were in tact. Found out one was broken. Replaced that and NEVER faced the same again.
    roadbreaker's Avatar
    Feb 2015
    21
    6
    I call it axle
    nabeelkhan's Avatar
    Oct 2008
    86
    516
    9 Post(s)
    is 'goda' and 'axle boot' the same thing ?
    Feb 2015
    21
    6
    Quote Originally Posted by nabeelkhan View Post
    Boot gody py lagty hain corners py.
    z0k
    z0k is offline
    z0k's Avatar
    Feb 2015
    21
    36
    Check ur gearbox mount... Im sure its broken!
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    any thing which holds weight and is not perform well in weight distribution thingy will putt stress on CV joint on cornering/turning it could be suspension/mounts even worn out bushes sometimes even if someone play with height of vehicle can all result in cv joint failure
