Results 1 to 8 of 8
Thread: a problem in cuore..
    trojan's Avatar
    Jul 2004
    29
    1,107
    Default a problem in cuore..
    yesterday i was driving and suddenly car started missing on idle like on signals and the engine shut off..i had to press accelerate to keep it open ..then after an hour i drove again and the problem vanished ..same problem happend in the morning ..and when i was cuming back there was no problem..
    the car is cuore.
    n forever shall the wolf in me desire the sheep in you!
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Well my guess is throttle body needs to be clean
    Imran Iqbal
    trojan's Avatar
    Jul 2004
    29
    1,107
    @iiqbal
    thanks for the suggestion .
    @all
    i would like other members to reply with more suggestions.
    omerjaved's Avatar
    Mar 2008
    86
    50
    Hi Trojan,
    May be you need the race adjusted. I had the similar problem with my cuore cx Eco 2007 model when running on CNG. If its a new car then may be you can drive it to the dealer , should not be a big deal.
    Regards,
    Omer Javed
    Desire the big thing!
    trojan's Avatar
    Jul 2004
    29
    1,107
    i dont think it needs race adjustment ..as it was fine when i was driving back ...
    i think there'z some other issue .
    Fuhrer_Hurricane's Avatar
    Sep 2006
    35
    1,065
    check if spark plug cables are properly tightened?
    is there any fuss in the connection terminals of plugs?
    We must know that around us is Pakistan, in us Pakistan marches and behind us Pakistan follows...
    omerjaved's Avatar
    Mar 2008
    86
    50
    Trojan,
    May be you have a different issue but for my case ,it did the same. Like on some trips it would run fine and at other times engine would turn off while applying brakes. Especially when started from a cold state. Sorry for that is all I can share with you right now. However, Please share your solution here when you do find one.
    Regards,
    Omer Javed
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Better solution is tunning of your car , which is cheap and Mechanic will check all small things , like cleaning of throttle body , Spark plug wire , Race setting etc
    Imran Iqbal
