AOA
Guy in December 09 .... purchased Nissan Sunny JX 1000cc 1992.... Car was in good condition in terms Engine work,body work and interior ..But required lot of cleanness in interior and exterior ,as the previous owner didn't maintained the car well ......So decided to do "Project Cleanness" on my car my self ....these are the things that i done myself.:P..:
Remove Front & rear seat, cleaned them with wet cloth & Carpet cleaner..
Remove all Interior Plastic Panels Including.. door panels,hand brake&gear Console etc, wash them and polish them.
Remove the front & rear Lights as some of their bulb are fused ,and all are very dusty , Clean them with water and surf...
Remove the inner carpet of car,it was way to dirty from inside ,clean it ,also clean the inner floor of car..
Wash the whole body ,then rub the door handle [between door handle and body] ,and some other body parts with Acid using tooth brush,this cleans the blackness closed to the edges of body as this cant be removed by any other thing...
Then compound polish the whole body ,using good quality compound..
Then at the end , polish the car with normal polish..
things that done by mechanic ....
Gear oil & Transmission oil changed..
Few engine seals are broken so changed them...
Car petrol system didn't work, as pipe was leaked ,so change pipe and check leakages..
New brakes pads...
So at the end of this little project , car condition was excellent....
whole day was spent in this project ,but it was worth it....most tiring job was compound polish...
bt raat ko jo dard hoa puri body
uffff.....
pictures are from my mobile phone camera ,,so might are some are not clear...
good comment from all members that visit this topic are welcomed...
before
