AOA , take a look step by step diy of meter lights changing to red ones just done last night. the only problem i face was lights are dim
gooda nice step taken
yar sara kaam Direct direct kia howa hai Bro, step by step to dikhaty
by the way nice work.
step by step hi to bataya hay there is one screw under front grill . obove sterio tap or deck baki to nai mushkil kahi bhi sab screws nazar aye ***
u didnt take off the green covers???
remove the green covers then c the result, also show how u used the celifin, or how did u make them red.
i did remove cover chinyoti bhai i will go to shoba for quality bulbs its very easy by using tap in this meter remove everybulb which has cap on it just remove and put that red paper plastic
its not very dark as its showing in the pic camra is not a good qaulity
try taking a pic wid ur mobile camera in nite mode.
u noe wat, dis isnt the same meter, the one i posted had numbers in wite too, but yes try the better bulbs too
hmmm maybe it had orange caps not green. let see
let me see ur post again it has 220 max speed meter as well i noticed
then also try using the orange caps
yar chinyoti there is one more problem this plastic thing smell like its burning inside . i will goto shoba to search somthing cool stuff
mayb the celifin used isnt off gud quality... or used more then required.
^ More celifin will result in more dim light.
i think i used too much cellofin just for proper red light result not for pinky one anyways i will go to shoba for brighter bulbs
please be carefull if ur smelling burning.
yup brother smell is gone now i think jitna jalna tha jal gaya bas bulb change karta hoon xli walay kahi say mil jaye to maza ajaye
@yasirsahave u changed the bulbs or just put coloured paper?
