Finally a long awaited swap has been started today...Its GA15de motor in my nissan sunny jx 93 also called B13. Thanx to Farrukh Ali for his guidance. He is always there when he's needed.One day I was surfing for turbo charger in shersha I saw this cleanest piece of GA15de. I booked it and then it started today.Suggestions are welcome...
now the old man is going out making room for new guy..... clutch n pressure plate were good as new so no need to replace..
@samar how much does a g15a costs around in shershah n wats the cost for the swap.
Good Going DOC>..................!! That Pajero Still There...Lolxx.....In A Day or Two.......I Will Be Visiting Myself......!!! I Told Tariq Bhai To Work As Clean As Possible But You Also Check Yourself Daily......!!Good Luck For rest Of work....!
congratulation
Very nice and clean engine you got! best of luck!
thanx every1@ser yup im in contact with tariq bhai my brother is there at his place as u know im busy in mornings.
@samaryaar any idea k g15a kitne ka milega completen wat will be the swap cost in khyber
nyc..!!best of luck!at which workshop ur getting ur engine done?
tariq bhai @ tariq road
nice!!best of luck
Mashalla Nice, best of luck and share pics in speed
You will also have to get the complete pipe of air cleaner with sound-box for it. Start your search now :). Its a rare item. Air cleaner box is clean by the way.
best of luck...
Updates Doc???? Got The fuel Tank Done???? And Cranked Up The engine????I was Expecting It To Happen Today.....!!
yar ppl are so lazy... i had to stand on his head to complete the fuel tank stuff... well it cranked but was doin missing... i was not there brother was saying that plug wires were damaged n there was water in plugs...
