Atlast got time and started retrofit with bixenon FX-R 2.5inch projectors.One thing i have learned that it is better to by plug n play kits for retrofit like morimoto h1 because it is very difficult to keep up with original alignments but i have build very innovative mount which allows the adjustment of beam horizontally and rotationally.I have also added extra mods,smoked lights but want to make them unique so preserved the chrome rings,placed pvc led strip which was inspired by lexus IS and CCfl rings for angel eyes.
projector can be seen on this thread
https://www.pakwheels.com/forums/body-work-interior-paint-glass-appearance/206911-got-hands-bixenon-fx-r-2-5-inch-projector#post3680742
if any one need help regarding retrofit can also text me
contact number 03113114270
Tools and material Required
Dremel or any rotary tool,
Epoxy,
screw driver,
screws nuts and washers,
dryer or heat gun,
box bigger then headlights,
masking tape.
PLease do say MASHALLAH
Quad retrofit morimoto h1 projecter + Bixenon FX-R 2.5 projector [Completed]
rest pics will show
heat gun i used which almost destroyed the side of housing while prying but then i used hair dryer which worked very well and their is other method i used to open headlight,i took a box bigger then headlight and attached dryer in box, placed headlight in it and closed the box,switched on dryer when temp reached 60 degree took out headlight and placed dryer from were i was going to start prying after few seconds i was able too put my fingers between housing and lens then i simply pryed whole light in just few seconds.
Updated Pics retrofit completed
DRL mode
high beam
low beam
