VSS simply triggers the relay if voltage is greater than 13.5 & de-energizes the relay as soon as the voltage drop below 13v, voltage range is adjustable via POT,
finally the relay drives the auxiliary Lamps/Accessories thtz it.
VSS detects the Engine state if it is running & charging the Battery then it allows the auxiliary stuffs to use battery power ...
