I wish to use my spare radiator fan which is sittiing my storage to used at home for multiple purposes. Anyone know how I convert those to home use with the 220V as the radiator fans are meant for 12V battery.
Thanks a bunch
Any suggestions??
Just use Ac220v to Dc12v converter and plug it in. Or you can use 12v battery to be used when the elec is gone.
I placed one as exhaust at home using the 220V to 12V converter with good amperes rating.worked great for 3 years with better air flow compared to local ones
or place it in the box for Room Air Cooler
You need a AC220 to DC 12 V transformer having high amperes. You can get one around Rs. 150 to 250 from local electronics market.
Ur required Converter will b available from Collage Road Raja Bazar Rwp
Is it safe? Just for my info.
Get a used computer power supply. This will give you pure 12V with 10Amp power. This will cost you Rs 150 and will perform best. Have a look on the specification on the power supply before purchase.
@ysalmanThanks bud. You are the PAKWHEELer MacGyver! What else tricks do you know? Can you make bomb out of a bubble gum? just kiddin'
it is safe because voltage is reduced to 12V. i never faced a problem in 3 years
you can buy rechrgable battery sogo fan for 1850/-
