Revamped
Engine (NA) produces torque at certain high RPM and then its drops, this is because of the Volumetric Efficiency declines i.e. the engine can’t breathe any faster. Mechanical efficiency also declines at higher RPM, due to increased frictional resistance which further reduces torque at the output. As RPM declines from high levels these limiting factors diminish, allowing torque to increase.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
Q: This suggests that torque will continue to increase as RPM drops !?
<o:p></o:p>
Q: Big bang requires more fuel mixture, so what is the significance of combustion chamber size?
<o:p></o:p>
Q: Compression ratio is calculated at 100% cylinder filling, does it means that cylinder is not filled 100% all the time at different RPM with air/fuel, air or fuel only?
<o:p></o:p>
Q: Heat in engine is transferred from combustion chamber to walls into coolant, but through study of thermodynamics it is clear that fuel mixture when hot ignites better, so a 4 cylinder engine of let say 2500cc and a V6 2500cc will have different characteristics just because 4cycl have small combustion chamber, which allows the heat transfer at slower rate??<o:p></o:p>
Further in the statement at top the mechanical efficiency also drops, is that mean a big V8 engine will lose more as compared to small I4 engine?<o:p></o:p>
Q: Finally how to get a flat torque curve?<o:p></o:p>
