Subscribed. good luck budddy
is your brakes problem solved ?
Stock brakes, facing no problem.
https://vimeo.com/117277091
Guys! Check kickdown of my Alto. Who say tht AT has less power, actually kick down saves the time pressing clutch n shifting gear. At 150kph it came back frm kick down. Thts the way i smoked big guns on motorway.
https://vimeo.com/117278839
Pangaaay with Cygnus...
V8 wala be like ie ka ho gawwya ? is gola ma asa alto kuna khahn se aya
Watch kickdown
instant just like snap
what is kickdown? could you please explain?
auto gearbox when u push throttle it kicks down to a lower gear for better power
sent from an evil cell phone
it comes in all auto gearbox? or it is a special type of gearbox
nop any auto gearbox
Yeh u push ur foot sown hard it'll go down to lowest possible gear and will accelerate like anything
you swapped the engine without cat con?????? any problem facing becoz of absence of cat con and it seem that your car RPM are on high side
Cat converter came with engine.
came with engine :-! a cat con is a part of exhaust system it doesn't come with engine
Nice project man. Drive safe, with all of that power it becomes kind of difficult to control yourself Anyways what tire size are you using? If its stock then how much tire spin you've to encounter?
ya exhaust housing was intact with engine. It was taken from half cut
using 165/60/13 . facing no prob on controlling. i feel it much better on road grip also..
damn that cygnus wala must be shocked, I am sure this can go head to head with cygnus on motorway but please drive safe
