suzuki..i was hoping someone frm LHr will buy it, engine is in Lhr.
civic:, whatever is going rate in local market, and location. if engine is in lhr lhr rates will apply,
that is 3rd series of 2nd generation of silvertop. when you see serial numbers you get the idea from K and first digit.
mileage exact no idea. but it is tested on long drives and used in car for 3 months.
obviously,, for geneartor use, no power st pulley or a/c needed, no ecu needed too no gearbox needed with good clutch pressure plate etc.
. but i have all those parts some bolted and some unbolted off frm engine lying in store.
