there was never a 6 speed in 4age afm type engine so car is modified with gearbox and also damping sheet front of firewall shows, Gt dont have those unless owner himself decide to install one to reduce engine noise. There is no ABS installed which is should be there near wiperwasher bottle and pipes should be visible hence car looks a early 90's model without ABS nearabout 1994. The look of air filter shows the condition of air going inside engine and donest look healthy.
excuse my comments may be too straight forward ,, the car should be fast no doubt. The Islamabad number plate does have value as for car price once papers are checked in reg office. The orginal air inlet behind headlight should be used with new Denso airfilter regularly replaced.
My suggestion would be not to use redline limit in first gear because that will distroy the syncronizers in gearbox very quick. the Black top 4age20v ecu designed for 6sp with lower fuel cutoff limit to save the gearbox in 1st gear
as mentioned by spiderman clearly the speedometer dial is changed,, JDM models were NOT allowed above 180km/hr,,
i dont think it will pass 180km/hr top speed without rsm device unless tempered in dangerous way.
jasma headers are quite prominent:)
