Land Rover Range Rover vs. Toyota Land Cruiser Review
Utility
The Toyota will most definitely prove more convenient than the Land Rover Range Rover for those of you with frequent child-cargo. The Toyota Land Cruiser is a better choice than the Land Rover Range Rover with respect to hauling capacity, especially if you frequently need to carry a lot of gear or sizeable dogs. There's little the Toyota Land Cruiser can tow that the Range Rover cannot.
Performance
With that kind of horsepower, both the Toyota and the Land Rover Range Rover are true speedsters.
Dimensions
The Toyota Land Cruiser's tank is roughly the same size as the Land Rover Range Rover's, though the Land Rover Range Rover's is a little larger. The Toyota Land Cruiser and the Land Rover Range Rover compete for the same parking spaces.
Convenience
The Toyota Land Cruiser's fuel tank will need to be replenished somewhat more often than the unit in the Land Rover Range Rover.
Cost
The destination charge is a standard charge for transporting the vehicle from its point of origin to the dealer. It costs roughly the same to get the Land Rover Range Rover to the dealership as the Toyota. The Range Rover doesn't pale in comparison to the Land Cruiser with respect to gas mileage. The Land Rover Range Rover won't tax your gasoline budget considerably more than the Toyota Land Cruiser will. The Land Rover is tremendously more expensive than the Toyota Land Cruiser with respect to MSRP.
Handling
With their comparable turning circles, the Toyota Land Cruiser and the Land Rover Range Rover most certainly handle about the same into and out of tight spots.
Drivetrain
The Toyota Land Cruiser's engine is considerably more sizeable than the Land Rover's. Bear in mind that bigger engines may use more gasoline than smaller ones. Torque equals pickup, and the Toyota will have picked up and gone by the time the Land Rover Range Rover finally gets moving.
Comfort
Taller drivers will significantly enjoy the extra head room in the Land Rover Range Rover's front cabin compared to the Toyota Land Cruiser. The Toyota Land Cruiser is not particularly more spacious for your passengers than the Range Rover.
Overview
The basic warranty that comes with the Toyota Land Cruiser isn't quite as generous as the Land Rover's.
