Results 1 to 19 of 19
Thread: Power stearing Issue
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default Power stearing Issue
    AOA
    I hear a strange sound when i turn the stearing wheel on my FJ70 and close to lock on either side, the engie runs a little rough, i.e like there was some extra load on it. Also, i feel a slight decrease in returnability when turning back to the center position. There appear to be no leaks from the power stearing pump/reservoir. Could the pump be close to dying? What could be the best fix?
    Regards
    Flat six flattening things out!
    usairan's Avatar
    Jan 2006
    39
    168
    Check the power oil and complete check of all power steering seals.
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default @usairan
    No leakage, fluid level just the way it should be. any more ideas?
    bilalalam's Avatar
    Nov 2008
    40
    449
    8 Post(s)
    I see you have got some, make sure your wheels aren't touching the insides of the arches. There could be problem with alignment / camber adjustment that can cause over sized wheels + Tyres to touch the inside.
    Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
    I_M_I_2's Avatar
    Feb 2006
    34
    201
    Is your power steering oil of good quality? You may consider changing the oil as well if you did not put it in yourself and are not sure about its quality.
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default ^^
    wheels clear the arches just fine, oil is of good quality, belt tension is just fine. alignment camber angle is spot on. think pump issues?
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Hamza, pump issue. Period.
    MMC
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default ^^
    yeah thought so myself. oil in the reservoir had foaming, parts gone bust and oxidation kicking in. reckon i can find a new one?
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Quote Originally Posted by HamzahF View Post
    Normal behaviour of pump, turning radius stopper bolt not align properly.
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default @janj
    are you implying pump need not be changed? whats the fix on this?
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Of course you can. The joys of owning a Toyota.
    MMC
  12. #12
    imtishal's Avatar
    Sep 2006
    42
    3,881
    11 Post(s)
    the blades of pump are gone.Only solution is to change the pump,As the blades cannot be repaired or replaced.
    Qaiser Pal,I have not failed.But found 1 of 10,000 ways which doesn't work.....Toyota driver "I couldn't repair my brakes,so i made my horn louder"..When i was born i was so surprised that i didn't talked to one and half year..since light travel faster then sound,people appear bright until you hear them speak..If u can't convince them,confuse them
  13. #13
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Remove power pump reservior cap if foaming in oil is visible, keep the engine running at idle for 15 min. Let me know if the problem is solved or not.
    Janj
  14. #14
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default @janj
    Tried that just now, foaming still there, noise still there. It sounds a bit like a grinder being used on wood. Pump?
  15. #15
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Pump, pump, pump!
    mmc
  16. #16
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    Quote Originally Posted by raohamid View Post
    MMC
    @RAOMMC
    Hahahaha......that's a good one there,amigo!
    @hamzaf
    I would drain/flush the fluid(maybe a couple of times....CALTEX or ZIC only)!!
    Pump option can come later if all else fails!
    MEN DO IT AT DAKAR!!!
  17. #17
    HamzahF's Avatar
    Mar 2008
    28
    208
    8 Post(s)
    Default ^^
    @MITSU_MAN
    I am sure raohamid was referring to parts availability as one of the joys of owning a toyota amidst many others.
    You reckon this could be because of debris formed in the pump over the years?
    @raohamid
    All smiles eh...koi nai koi nai.
  18. #18
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Quote Originally Posted by MITSU_MAN View Post
    @RAOMMC
    @hamzaf
    Ma main man has such a one-tracked mind! I love this guy!! Hhahahahah!
    Well, now that you mention it Mitsu, sure sounds better the way you put it!
    MMC
  19. #19
    kool_munda's Avatar
    Jun 2009
    24
    364
    bro its the hydrolic power stearin and the pype needs to be changed and put quality oil in it ur problem will be solved inshaallah
