install a new fuel filter, and run the engine from a bottle of fuel in the engine bay, Seems like your engine is not getting any fuel. Choked filters cause this. Does the engine behave correctly without any drive load, meaning if you rev in Park or Neutral, It should idle normally, all injection lines should have even pulsing and the noise should be minimal.Also disable the EGR and block it off. You should also inspect the inlet manifold for gunking up and clean it out.
