Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Death_ride
Thread: Oil as Coolant in radiator.
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Default Oil as Coolant in radiator.
    How many of you have gone thru the experience of pouring some little motor oil in your radiator as substitute when not having a coolant.
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    Death_ride's Avatar
    Jun 2005
    Melbourne
    34
    449
    Never done this myself but know some ppl who have done it....it's a two way debate I would say, water has more conductivity and evaporates and sometimes corrode ur cooling system...oil gives u a good flow at a very high temperature, but only if u use the right viscosity....u may have a chance of blocking the cooling system...cause the oil is not going to be hot all the time specially in a cold morning...the cooling system has a lot of tiny and narrow pathways that only water flows through so have a chance of blocking those with oil....I would rather suggest using a high quality radiator coolant instead of mixing a little oil....normally u don't have to change or refill radiator coolant in new cars for 6 months(sometimes much more) I have a 21 yr old engine and don't change the coolant for three months sometimes....as long as u take good care of the engine and cooling system...it should be ok with a radiator coolant unless u drive erratically and smash the sh*t out of the engine, u shouldn't be worried.....
    I have a drift car as well for which I change the water pump, check water hoses and change the coolant everytime I go for a drift...for such purpose car I would never recommend the oil mixing method...
    Fellow members might have different views to all this...
    342HP on a small hatchback really is fun when u only have to play with just over 1000Kg
    7606's Avatar
    Dec 2010
    Rawalpindi
    267
    5 Post(s)
    never done it
Tags for this Thread
