Results 1 to 15 of 15
Thread: Tire Pressure for Off-Roading
    Faysall's Avatar
    Jun 2005
    T.O
    38
    1,784
    Default Tire Pressure for Off-Roading
    I would like to ask as 2 what should be the ideal tire pressure for
    a) Rocky terrain
    b) Wet n damp areas (like the seashore,on the banks of rivers)
    c) Sand dunes
    Kindly clarify by means of easy jargon.
    Cheers
    Slow down and enjoy life. It's not only the scenery you miss by going too fast - you also miss the sense of where you are going and why.
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    tire pressure enough for fairly large tire foot. you didnt mention any tire so no tire pressure can be identified without a specific tire.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    nak
    nak is offline
    nak's Avatar
    May 2006
    Peshawar
    86
    3,521
    man all the way low tyre pressure..e.g if u r having 28psi, reduce it to somewhat 20psi
    http://www.pro-pakistan.com/
    ________________________________________________________________________________________________________________________
    Nearly all men can stand adversity, but if you want to test a man's character, give him power...(Abraham Lincoln)
    Faysall's Avatar
    Jun 2005
    T.O
    38
    1,784
    @levin
    the tyres in question are Yokohama Geolander (rotational).
    I will provide more info later.
    cheers
    Faysall's Avatar
    Jun 2005
    T.O
    38
    1,784
    the tyres are
    265/65/17
    I/T
    Yokohama geolander
    Salarzae's Avatar
    Sep 2005
    Select City
    12,477
    31 Post(s)
    3 Thread(s)
    For Dune bashing the ideal is 13psi but if u r too fast and sand is little hard, try 15psi. More then that and sand will suck u in.
    This Space Intentionally Left Blank.
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    salarzae...dont u think thats too low? thats normally half of what u would drive with on the street. i have no personal experience so i dont know shyt...
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    a) original tyre pressure
    b) original tyre pressure
    c)12-16psi depending on vehicle weight & wheelbase
    Voyager's Avatar
    Aug 2004
    42
    3,744
    3 Post(s)
    Deflation is often controversial, yet an important technique that should be practiced and implemented. Here are a few guidelines:
    - Deflation improves traction but reduces ground clearance.
    - Wheelspin with deflated tyres may cause the tyre to ‘debead’, that is to come off the rim. This may happen in rocky or sandy conditions.
    - Tyres should be deflated when cold, not hot (hot air expands and gives higher tyre pressure readings). You could unseat a tyre from its rim when it cools down.
    - In rough terrain, deflation also allows tyres to absorb more shock.
    - In rocky terrain, deflated tyres can mould themselves to rocks as they go over them.
    - Inflate tyres as soon as possible. Select your tyres according to the road conditions where most vehicle usage takes place.
    It is important to consider these factors: size, width (this has an influence on flotation) and load/speed rating. Check wheel balance and alignment after protracted rough off-road travel.
    Sand: Lower pressure to increase traction. It is worthwhile to deflate the front tyres only, as this will compress the sand for the back tyres to ride over. As hot sand has little moisture, it is looser and more difficult to drive on.
    Keys to successful sand driving are momentum and tyre pressure. Deflate your tyres (45% of normal pressure is about the limit). Momentum and speed stop the vehicle from becoming mired in the sand, while dropping your tyre pressure creates a bigger tyre ‘footprint’, spreading the vehicle’s weight over a larger area and giving you more grip.
    So drop your pressures when you are driving in hot sand or in gravel (it will give you a more comfortable ride), but remember that fast cornering on soft tyres is highly dangerous (you can roll the tyre off the rim), and don’t forget to re-inflate when you are back on hard ground.
    * Never brake hard in soft sand. Your wheels will dig in and you’ll stop faster that you expect. Simply * decelerate, as the loss of momentum will halt the vehicle.
    * Always stop on a downhill or on the flat.
    * Avoid wheel-spin – the vehicle will simply dig down into the sand.
    Rocky Terrain: Whilst deflation allows better grip, be careful not to spin or pinch a softer tyre as this could unseat the tyre or damage the sidewall.
    Mud: Slightly lower pressure will increase the surface area and improve flotation, but beware of hidden obstacles.
    Water: Do not lower pressure in water as obstacles under water may not be visible. It also lowers the vehicle’s clearance.
    It would "go places where tankers quit and birds would go back exhausted." *****Willys MB*****
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    For ( c ) low tyre pressure is recommended, on ( b ) you can also have low pressure, but Never try low pressure on rocky terrain, otherwise they might rock you up...
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    iffe's Avatar
    Feb 2004
    34
    1,031
    8 Post(s)
    great info voyager bhai
    He who hesitates is not only lost but miles away from the next exit
  12. #12
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    I think Voyager is our resident expert in terms of off roading.
    @voyager
    good write up.
  13. #13
    oodbalow's Avatar
    Jun 2006
    Select City
    40
    17,047
    4 Post(s)
    Rocky Terrain:
    Gravel: increase tyre pressure a little bit than ur normal paved road ride.
    Solid rocks: increase tyre pressure by 5 to 10psi.
    in rocky terrain increased tyre pressure will save the tyres aswell n give u better performance of ur rig.
    Wet n damp areas:
    Water: Normal pressure (depends upon some conditions)
    Sand: decrease tyre pressure nearby half
    http://www.facebook.com/oodbalow
  14. #14
    ateekt's Avatar
    Feb 2006
    Select City
    18,162
    @ Voyager:
    Right said...! I agree with you...! Nice info/post, keep it up...!
    --- Bmw is not in my blood - It's in my DNA!! --- Admin/Founder/Recruiter @ Pwcid ---
  15. #15
    portage1's Avatar
    Nov 2005
    hyderabad & Michigan
    10
    21,004
    37 Post(s)
    3 Thread(s)
    i agree with voyager
    I'm a freak who lost his mind in the busy world of today and takes his frustration by being funny with others
