So i thought that rather than starting a new thread lets just revive this one, So amongst other preparations that have been going on with regards to the project i recently came a across a scale model, build it yourself kit for the 2nd gen 4runer and i thought Why not!! So here is the result... the rally spec (read cut and b**terdized) Kaikra, should look something on these lines once its done... Khyaalaat are welcome..
Ive offset the rubber on the wheels to mimic the install of the long travel suspension. Also for some strange reason the rake is off with the model much lower upfront. With the actual vehicle the rake will be the opposite with the front being higher than the rear. I'm still debating whether the wheelbase should be extended. Lengthening the wheelbase does come at the expense of a longer turning circle. For starter we'll keep the wheelbase as is.... in the end this is what it should look like.
Fantastic! The real test should be the jumps and the bumps.
The LT kit properly installed should yield these results... exact same kit on the truck (with the right shocks of course)
(Y)
Sent from my GT-I9500 using PW Forums mobile app
That landing had to have hurt
Oye engineer ustad, anj nahin banayee da gaddee ajj kal Mehnat karein, mehnat! Abhee to party shuru bhee nahin howee
Has the white evo been restructured or qasim bhai has 2? As he was spotted on a great looking white evo
Have 2 Evos
Rally's Evo is still not finished
@suhaibkiani sir g ye design galat hai....it has a wheel at the back instead of engine
Guru ji , hum ne sirf body kaatni hai aur taange lumbi karni hein... aap nae to plastic surgery aur open heart surgery aik saath kar dei hein . Wallah itna barra engineer mein naheen hoon...
Itna hee simple hota, to ab tak karr chukna thaa!The proportions on your "model" are wrong and it doesnt even look like a Hilux! Ab khayaali polao band karr dein, dimagh kee lassi bhee maaf karein aur sharafat se Hi-Lex kee offer dalein, sasti dilwana mera kaam!
Baat hisaab ki hai, der hisaab ki wajha se lagi hai, anyway proportions ghalat hi sahi..leni yeh ya us ki kamaniyon wali behen hi hai... i'll quote someone here "if you don't believe in what you're doing it'll never work"...and boy do I believe in this thing...
Dobara hisab karein! Hi-Lex Kaikra + IFS Conversion + 5VZ install = winner
1UZ aur clutch chit meray khaatey mein!
1UZ kay dushman kab say banay?
Dushman nahin, mujhey chaaheeyay hai aik
Sir Jee, kucchh kharcha kar kay proper rebuild karain
What exactly do you mean by a "proper" rebuild? That has become a rather bastardized word in my books.
Trickster question: why should one just not buy a fresh piece, which would probably cost less?
