I own a Jimny o2 (soft-top) 2003 --- Its about time i change its tyres --- i have seen most pakistani offroaders in Northeren and Hilly areas with General 6.00-16 tyres (GENERAL TYRE AND RUBBER COMPANY OF PAKISTAN LIMITED). I was hoping to add the same tyres to my jeep. What are the pros and cons --- Please advice. Also my Rim size is 15 so i will need to go up one size as these tyres only come in 16" rims.
Regards
You should stick with originalsize and find some tire for that size
It depends on the usage, General type treads and tires work well for commercial purposes: hard to break / easy to replace / low cost / long life. Probably not the best choice for city / daily runner type uses.....
I would recommend Yokohama or Bridgestone, both should be A/Ts only.
The Original Tyre size is 205 70 R15 and i cant find any AT tyres in lahore of this size ... can anyone help.
205/70-15 is easily available. another option is 215/65-15.
I've found the tyre size in 1: YOKOHAMA GEOLANDER (Rs.16.5K) & GT Radial SAVERO AT (Rs.10K) i m going for GT SAVERO AT.
