Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Like Tree5Likes
Thread: (cold start) engine knocking on new 2kd-ftv
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    Exclamation (cold start) engine knocking on new 2kd-ftv
    hi there as the title indicates whenever i cold start the 2kd-ftv(turbo) engine ( 10k kms driven) the engine starts knocking that fades away after 1 min. is there something that i should be worried about or is it normal? currently i'm using total's rubia HD Api-Cl4 (15w-40) engine oil.
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Cold starts are usually that way for diesels. Modern diesels warm up pretty quick since their glow plugs are electronically controlled and are run constantly till the engine is upto optimum temperature. Nothing seems out of the ordinary.
    For personal satisfaction you can always have the glow plugs diagnosed.
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    Quote Originally Posted by sherwan_88 View Post
    thanks for your reply i was kinda worried k ye knocking q ho rahi hay
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    Quote Originally Posted by Maxud1 View Post
    knocking or missing?
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    Quote Originally Posted by ToxicDevil View Post
    bro tbh i'm not a car geek nor do i know what is missing but whenever i cold start especially in the morning there is tak tak tak tak sound that fades away after a while
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    What Is Diesel Knock? (with pictures)
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    thanks brother for the article .. so it means its normal i thought theres something wrong with the engine oil,, btw as winters are coming i doubt 15w-40 will be suitable for cold start but i didnt find any 5w-30 oil for diesel engines so what to do in this case :/
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    I dont have much knowledge about diesel engines but low oil flow due to bad pump or because of thick oil in winters also cause a rattling sound tak tak tak tak. Similar sound is also the result of loose tappets (valve clearance).
    Better wait for a reply from someone who knows of diesel engines.
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    ok thankyou so much bro , appreciate your help
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Every engine will have all the oil drip back into the sump overnight. When you fire it up in the morning it take about 15-45 seconds to get the oil circulated in the engine. Diesel's sitting cold have to work harder since their ignition is solely based on cylinder temperatures. So when a diesel is started it takes time to get the temperature up and in that time engine knock occurs.
    If the oil pump was bad, oil check light would come on in intervals during a drive and the car would overheat. Diesels rely heavily on oil cooling as diesels run twice operating temperatures and compression than gasoline engines.
    In most of Pakistan there is no need to run a low viscosity oil unless the car is intended to run in sub-zero atmospheric temperatures.
    Low viscosity oil's tend to shear quickly in a diesel engine when its under load.
    Maxud1's Avatar
    Jul 2013
    291
    12 Post(s)
    thanks brother for your detailed reply , appreciate it i think am now clear that my vehicle is performing normal and there's nothing to worry about.
  12. #12
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Please use good quality diesel fuel from a reliable filling station
  13. #13
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    And never drive the vehicle / engine until or unless the temperature Guage has risen slightly
  14. #14
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Toyota's KD series engines are excellent
    But require a lot of care for a longer life and better performance
  15. #15
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    I change fuel filter for my Hilux 1KD & Land Cruiser 1HD-FT every 5000 KMs
    As most filling stations tend to give low quality diesel .
    Many times i found the fuel filter containing water
  16. #16
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Also note that most local shops sell air filters & fuel filters with toyota packaging
    But actually they are made in Rawalpindi & Lahore
    Always buy filters from reliable points
  17. #17
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Their is no place in the world where you won't find a bit of water in diesel fuel.
  18. #18
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    And last but not the least.
    Whatever engine lubricant you use
    Always buy from some reliable shop
  19. #19
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Yes but that little bit of water can ruin the engine
    If the fuel filter isn't A+ quality
  20. #20
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Fuel filters do not seperate water. They are particulate filters and not medium filters.
