i suggest you contact the IJC guys directly.
do note that design is less important than mounting points. if the rollcage is not bolted to the chassis it is not likely to be of any use.
so what you need to do is find the ideal locations for the mounts and then work the pipe design around the available options (whatver looks best to you).
