Dear rizi bhai, first of all iam sorry, because i have busy days my medical tender business is started.
So below if you do with 100percent determination and honestly. You can get the perfect shine which you are looking for, But first to get all the polishes you need almost Rs 7,050/- (Means Turtle Platinum Car Wash Rs 650/-, Turle ICE Synthetic Paste Wax Rs 2,200/- and Turtle ICE Liquid Synthetic Wax/Sealent Rs 2,200/- and Synthetic Clay Bar set with Clay Bar Lubricant Rs 2,000/-) This will be your first time investment.
Your car is in good condition no need of any polishers machine. Just do good with your own hand and also start this work at 9.00am and u will finish it on 4.00pm max.
STEP1: (Donot do this procedure under direct sunlight because if you do a tiny droplets of water will be seen on glass/body, do this job in garage)
Wash your car with water, but donot wash your engine compartment because of the ECU. After thoroughly rinse your car with Water. Try to make a thick foam of Turtle Car Shampoo Turtle Platinum Series (Green Silver Dabba). Try to wash your car atleast 03 times to make all the dirt clean and more you wash your car with shampoo its easy to clean.
STEP2: (Do this step in your garage no need of exposure of sunlight)
After clean and dry your car with soft cloth, dont use hard cloth otherwise scratches will make and make sure you clean all the water, inside door panels, below door panels, back trunk.
Use Synthetic Clay Bar Kit (A video is attached for your reference), its simple to use, just watch carefully the video.
STEP3: (Do this step in direct sunlight because Turtle ICE Synthetic paste wax recommends to do wax direct sunlight so that the chemical bonding will be good)
After done all the clay bar stuff, use turtle ICE synthetic paste wax and applied the wax by using sponge, and donot make circular motions because the factory guyz already done your car polish in circular motion, so you do in zig zag by pushing hard and make it dry, in this type of polish u need extra energy. and its better to take 05 mins break. But donot drink water.
After waxing your whole car, wait for 05 mins and then clean the polish with turtle ice cloth which is in the pack, and after that you clean all the polish.
Try once more to apply the same paste wax to get extraordinary shine and this time you do the polish right to left motion, not up and down ok. After applying the wax on whole car, wait for 05 mins and clean whole the car with cloth.
STEP4: (This step should be done in direct sunlight so that the shine and sealent can get good chemically bonded and the particles/molecules of paint and sealent become a solid reaction and the catalyst is used SUN means heat.)
After you have clean the car with paste wax, Use Synthetic ICE LIQUID WAX/Sealent. use minimum of liquid and you can use this liquid on every part of body except glass. If you dont One coat of ICE Liquid do another coat of ICE Liquid.
After that your car will give an extra ordinary shine, just like mine and plz do post pictures after doing all the 04 steps honestly with the same products.
Below are links for your help: Just listen them carefully
YouTube - How to use a clay bar on your car
YouTube - Ice Liquid Polish from Turtle Wax
below are the pictures of products which i have recommended, sorry for bad quality pic because of my cell phone:
