Saad Khan bhai, thanks for your kind words. About your questions, the engine on this car is very similar to any other 800cc car. All engines are for small cars like Mehran and Revo are very basic and have very similar internal parts. Any mechanic can easily fix them. Multan is not a small city Saad Bhai, I am sure you will find a good mechanic if needed. But why worry brother, you are interested in buying a BRAND NEW CAR. This is why people buy Brand New Cars over older cars. You can buy a used Toyota Corolla 82 or 84 model for about 3 Lakh, but You will get a USED car, and always have to worry about fixing that, but in case of Revo, you will not have to worry for atleast first few years about any serious engine problem.
The basic Maintenance is very important.
If you keep in mind to always warm up the engine every morning. Do not race the engine too much when car is not moving. Never redline, the engine, meaning in some cars the Revolution Per Minutre, Techometer, RPM Meter, indicates when you are racing the engine too much. So, if you are careful driver you can avoid alot of problem by just driving sensibly. And always change the engine oil and oil filter after every 5,000 kilometers. This will keep your engine running like new for a long time.
About the suspension. This car has very sturdy, good suspension. The back suspension is Leafspring(Kamaani system) with shock absorber. Meaning, you can go thru speed bumps and bad road conditions without damaging the Rear suspension, just like Suzuki Pick Up, that has leafspring. The front suspension, is strut with coil spring. This is also very strong, and sturdy. I have not seen Kamaani system, leafspring in the front of any car, except KIA Seres Pickup, in Pakistan. That makes the ride very rough, but extremely sturdy. But Strut and coil spring, like in Revo, is standard and any mechanic can fix it easily.
This car has Steel beams, running under the front fenders and door pannels. Very strong, I don't think even Suzuki Cultus, or other small hatchbacks in Pakistan have such safety features.
Caution is always is the best way. Drive carefully and watchout for other's mistakes, you can avoid alot of problems by just driving carefully.
About the booking of this car, Rawalpindi/Islamabad now have a booking office, near Pir Widhai area. I think Multan also may have one. Please check the Adam Motors website for details on Dealerships and booking.
www.adammotor.com
Below are the vehicle specifications for Revo 800cc std.
Type 4- stroke cycle, water cooled, OHC
Displacement 797 cc
Cylinder Layout In-line-4
Bore & Stroke 62.0 x 66.0 mm
Max. Output 35/ 5500 (ps/ rpm)
Max. Torque 52/ 3000 (N.m/ rpm)
Fuel System Carburetor
Transmission
Transmission type 4 Forward, 1 Reverse
Chassis
Steering Rack & Pinion
Suspension Front Strut With Coil spring
Rear Leaf Spring With Shock Absorber
Brakes Front Disc With Booster
Rear Drum
Tyre 145 80 R 12
