Results 1 to 7 of 7
Thread: how can u identify Honda CL7 & CL9 ??
    skybolturs's Avatar
    Apr 2005
    33
    327
    Default how can u identify Honda CL7 & CL9 ??
    ENgine wise and look wise what is the basic difference?
    skybolturs's Avatar
    Apr 2005
    33
    327
    any body can differiante b/c CL-7 CL-9
    come on guyz
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Visual differences include front grille and a dual exhaust for the 9 and the rolling stock is different. not a Honda guy, some other's will be able to tell you more.
    |||||||||||||||||||||||||||||| C2G - GARAGE | SHOP | TUNE +92 346 8776643 |||||||||||||||||||||||||||||||
    khattak's Avatar
    Jul 2005
    Peshawar
    37
    565
    GENERAL
    Body type Sedan Sedan
    Drive FF FF
    Transmission Electronic control 5 speed automatic (S matic) Electronic control 5 speed automatic (S matic)
    Displacement, cc 1998 2354
    Frame UA-CL7 LA-CL9
    Price of new car, thousands yen (Tokyo area) 1990 (~$16500) 2150 (~$17900)
    SPECIFICATION (SPECS)
    EXTERIOR
    Exterior dimensions (LxWxH), mm 4665 x 1760 x 1450 4665 x 1760 x 1450
    Interior dimensions (LxWxH), mm 1940 x 1485 x 1185 1940 x 1485 x 1185
    Wheel base, mm 2670 2670
    Treads (F/R), mm 1515 / 1515 1515 / 1515
    Ground clearance, mm 150 150
    Curb vehicle weight, kg 1370 1420
    Gross vehicle weight, kg
    Seating capacity, persons 5 5
    Doors number 4 4
    Min.turning radius, m 5.4 5.4
    Fuel tank capacity, l 65 65
    ENGINE
    Engine model K20A K24A
    Max.power (Net), kw(PS)/rpm 155 ps (114.00 kw) / 6000 rpm 200 ps (147.10 kw) / 6800 rpm
    Max.torque(Net), N*m(kg*m)/rpm 19.2 kg*m (188.29 N*m) / 4500 rpm 23.7 kg*m (232.42 N*m) / 4500 rpm
    Power density 8.84 7.1
    Engine type Water cooling serial 4 cylinder DOHC Water cooling serial 4 cylinder DOHC
    Engine information I-VTEC horizontal ranging chaindrive I-VTEC horizontal ranging chaindrive
    Fuel system Electrically controlled gasoline injection system (HONDA PGM-FI) Electrically controlled gasoline injection system (HONDA PGM-FI)
    Turbocharger No No
    Fuel type Unleaded regular gasoline Unleaded premium gasoline
    LEV system (Low emission vehicle) Yes Yes
    Compression ratio 9.8 10.5
    Bore, mm 86 87
    Stroke, mm 86 99
    Final gear ratio
    Fuel consumption at 10-15 modes, l/100km 7.2 8.3
    Fuel consumption at 60 km/h, l/100km
    CHASSIS / TRANSMISSION
    Power steering Yes Yes
    Tires size, front 195/65r15 91h 205/55r16 89v
    Tires size rear 195/65R15 91H 205/55R16 89V
    Braking system, front Ventilated disk Ventilated disk
    Braking system, rear Disk Disk
    Suspension system, front Double wishbone type Double wishbone type
    Suspension system, rear 5 links double wishbone type 5 links double wishbone type
    EQUIPMENT
    EXTERIOR EQUIPMENT
    Sunroof / Moonroof
    Front fog lamp
    Rear fog lamp
    Xenon headlight (Discharge lamp)
    Projector headlight
    Rear wiper
    Front spoiler
    Rear or roof spoiler
    ABS (Antilock brake system)
    TCS (Traction control system)
    LSD (Limited slip differential)
    Privacy glass
    UV cutting glass
    Aluminium wheel
    INTERIOR EQUIPMENT
    Air conditioner Full automatic Full automatic
    Wood panel
    Cruise control
    Centralized door lock
    Power window
    Steering wheel telescopic
    Steering wheel tilt
    Leather steering wheel
    Power front seat
    Power rear seat
    Leather seat
    Falling down type rear seat Divided type Divided type
    Child seat fixed with seat belt
    Rear ELR3 point seat belt
    Front seat pretensioner seat belt
    Fourth limited front seat belt
    Side impact bar
    Airbag (Driver)
    Airbag (Passenger)
    Airbag (Side)
    Audio deck AM/FM radio AM/FM radio
    CD-player Single equipment Single equipment
    Car navigation system
    - present - not present - option
    HONDA (hon-duh) (noun) Swahili for "i will get a real car when i grow a real D**k"!!!
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    nice reply..khattak.. hope yr doing ok?. you been away for a while??
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    khattak's Avatar
    Jul 2005
    Peshawar
    37
    565
    sorry, that didnt come out as it should have. just remnember, info about both cars is given one after another. i mean, "Frame UA-CL7 LA-CL9" means that FRAME is in first coloumn, UA-CL7 is in second coloumn and LA-CL9 is in third coloumn. likewise, interpret all data in three coloumns. or just refer to the below given website. its the best that i have come across about Japanese cars.
    http://english.auto.vl.ru/catalog/honda/accord/2002_10/photo/
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,130
    7
    49 Post(s)
    2 Thread(s)
    really nice info@khattak
    FXXB and EJ8 on its way............
