Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 201 to 220 of 250
Like Tree49Likes
Thread: Project GTO
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Default Project GTO
    Hi Guys, i m a two stroke lover n as u know already i have a great 2stroke bike made in japan YAMAHA RX115,its a great bike n i love to ride.
    Few months earlier when SKM came bake and decided to launch the bikes again at that time i did wish for GTO 2 stroker.............
    now you now there aint any 2stroker so i decied to restore my KAWASAKI GTO125.
    It is 1990 model n i bought it in 20k about month ago. chrome,colour work is in process n i get it on 18 august.
    i have already bought new body parts and etc................................80% parts r genuine n imported from THAILAND, like speedo meter,starting coil,chain cover,carb,iginition swith,mud guard set,sporket set,chain,engine covers mono gram,swith cover,throttle cable,clutch plates,rear shocks,handdle bar,grip swith,wiring,all bearings,all reflectors,gear lever,kick,piston set,baffale,fuel gage,front mono gram.
    some parts are local like,side covers,tail fairing,tail light cover,front fairing,head light,clutch n choke cabbles,indicators,brake n clutch lever.
    some parts r bought from bilal ganj(Lahore,s junk yard) like,rear drum plate,magnet and starting coil set.
    other parts r gonna restore like fuel tank,rims,servo disk,front shocks,head cylinder,exuast,seat,filter,brake padle n engine.
    guys i need your suggessions and critical comments for the sake of bike.i will post the pix for viewrs.Thanks.
    PROJECT  GTO -601941
    PROJECT  GTO -601942
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  2. #201
    OffRoad's Avatar
    Oct 2006
    39
    2,214
    17 Post(s)
    If you want to check my current projects plz clink on the below link.
    https://www.pakwheels.com/forums/4x4...roads-new-ride
    And Also attach the Pics of Yamaha TDR 250
    Its Dual Cylinder, Two Stroke,Dual Carborator,Mono Shock,Water Cool, Isb Reg 2001.....Now a days its in Lahore for restoration work...
    PROJECT  GTO -128028 PROJECT  GTO -128029
    Please do contact me.I am also a two stroke lover & always bulit beautiful machines from Junks
    "Fun Begins Where Road Ends"
  3. #202
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    you can have the cylinders professionally rebuilt - I did one cylinder for a KE175..
    Firstly I stenciled all the ports onto a paper - then marked all the angles of how the port is aimed. Get a cast iron sleeve and have it only a smidge (about 0.8mm) oversized for the empty cylinder barrel and make all the ports nicely and they should be aimed perfectly (I use a precision drill for it) - NOW is the hard part - you would need to freeze the cylinder liner (sleeve) to below frostbite temperature - dry ice or liquid nitrogen works nice - heatup the empty cylinder itself in an oven or with a torch while spinning on a lathe.. Remove from lathe and insert chilled liner into the barrel and align all the ports - the liner may need to be pushed into the barrel. Once cooled off it will be seated super tight - The usual desi way is not a tight interference fit. The loose fit makes them not shed their heat evenly resulting in siezed pistons
    The above kind of fit will make the cylinder perform like original and its actually the size and aim of the ports that dictate the power delivery of an engine..
    After boring and honing - you need to greatly bevel the exhaust port upper lip and also bevel all the transfer ports to remove any sharp edges that can "bite" the piston.
  4. #203
    Farooque's Avatar
    Nov 2006
    Here
    37
    189
    Xulfiqar...
    The way you work impresses me! (Bravo!!)
    One must really be able to pause and think, to appreciate the minute details, which in the end matter!
    Anyways, in the desi way, when the sleeve is pressed into the cylinder, do you have figures that by what factor it is actually oversized...
    Pakistani technicians are very bad at detailing...
    During my research a long time back, I remember reading somewhere that alloy based sleeves are used (instead of cast iron) for aircooled motors, due to their conduction properties...and this may also be another vital key to longevity, ofcourse after having pressed in the sleeve in the manner you have shared!
  5. #204
    YamahaYB100's Avatar
    Sep 2010
    28
    1,165
    16 Post(s)
    impresses jee
  6. #205
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Farooque View Post
    Xulfiqar...
    the oversize you are mentioning is the piston oversize - they come in 2 oversizes, 0.50mm and 1.00mm - this number is the extra width the piston diameter has.
    When a cylinder is resleeved - they make it back to 0.0mm (the performance problem is what I have already mentioned. the port aim, shape and stagger - then on top we have an ill fit sleeve that cannot shed heat fast enough as the cooling fins have lost their contact on the liner when it heats to normal temperature - which results in the sleeve contracting, (because its round), the pistons expanding along with the rings and eventually heat siezing
  7. #206
    nasir007's Avatar
    Sep 2007
    1,576
    6 Post(s)
    Keep it up !!
    "Live Fast, Die Young and Leave a Beautiful CORPSE "
    How much horsepower gain do you get from your NOS sticker ?
  8. #207
    faizy207's Avatar
    Jun 2008
    33
    769
    maan gaye boss BOHUT AALA
    If u obey all the rules u miss all the fun...
  9. #208
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Bhai faheem Allah aapko kawasaki mubarak kare aur is kawasaki ko faheem mubarak ho that she got such a great lover
    Kawasaki is the longest wheel base bike in pakistan in the range of 70cc to 200cc
    karachi mein ise bike ka Husn kaha jata hai
    sounds great with speed aswell as grip due to long wheel base
    mere bhi dil mein hai aaj nai to kal aik kawasaki Allah mujhe zroor dega ameeen
    sincere and pure wishes for ur restoration
  10. #209
    2StrokeLover's Avatar
    Nov 2012
    30
    54
    2 Post(s)
    Default My Kawasaki GTO 125 restored on 95% it's own genuine parts.
    Faheem bhai ka juab nai, Masha Allah bot achi bike restore ki ha...
    Faheem bhi please mujhay bhi tips day mari Gto 125 ko or bahter kernay k liay
    Ya 0.0 size cylinder per ha (Made in Thailand) baki sub parts is bike k apnay genuine han, saray nut bolt is genuine han...
    Genuine cylinder, genuine piston 0 size bilal gunj say arange ker lia ha, ab Pakistan a ker install kro ga
    I am second owner of this bike, bike is on Original registration documents.
  11. #210
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @2strokelover, bro you already have nice gto, best of luck bro
  12. #211
    essamkhan's Avatar
    Jul 2011
    16
    zabardust zabardust ...kia restore thi alaa yar
  13. #212
    ubaidz's Avatar
    Apr 2011
    121
    5 Post(s)
    A great GTO marvel you did couple of years ago bro,
    It was treat seeing this thread and your work and exp although too late but worth watching.
    ub
  14. #213
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    Buddy! where did you get this picture ?
    Quote Originally Posted by RX115 View Post
    PROJECT  GTO -601941
  15. #214
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @ubaidz, my pleasure bro, thanks @vickytulla, bro theek se yad nhi ab, about the exact location of the pic, but took it by google help,
    does it belongs to you or your friend?
  16. #215
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    the shadow reflection on tank is of the person who took the picture was me - date 2009 Febuarary, owned by friend who came o my whom to show me his Rocket.
    but took it by google help, does it belongs to you or your friend?
  17. #216
    ubaidz's Avatar
    Apr 2011
    121
    5 Post(s)
    Bro Can I still get parts for the GTO100 containing engine GTO125
    Yu from Rwp?
    ub
  18. #217
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ vicky
    kamal question
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
  19. #218
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by ubaidz View Post
    Yu from Rwp?
    i didnt bought parts from RWP, rather i bought it from LHR, pindi guys do buy parts from LHR, here isnt any good n specific junk shop regarding gto parts,
    if you need to buy then just visit BIlal ganj bike junk shops, there you will must find many more,
    there is a guy named Asad, his shop in basement, he use to deal in gto scraped engines, most of the gto125,s engine lots arrieved from Dubai, and engines would be made in thailand, if u wanna use thai engine then do not go for it, specially its cylinder blocks and carbs, rather if you need only gear box then you can go for it,
  20. #219
    ubaidz's Avatar
    Apr 2011
    121
    5 Post(s)
    the engine which im running on is genuine of GTO but the ring or piston do sound like Trr while moving.
    Ineed 5gear box I will visit bilal gunj as It is the only place here, Infact I was looking If anyone have That box with them or from Scrap GTO grounded somwhere.
    and can gto125meter's fuel gauge setup can b done on GTO100's Tank by any means?
    ub
  21. #220
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    if you are going to install 5speed gears in gto100,s engine then it can install but in my opinion dont go for it, coz its use less on 100cc emgine, coz 100cc wont need 5speeds rather its original 4speed gear ratio is already set according to its power,
    yes one can install fuel gauge set in 100,s tank, you have to buy a fuel gauge and gto125,meter
