Does the self go properly, i.e. does it sound as usual? Does it start ok on kick?
sounds as usual, Bike starts in one kick.
Also make sure that the cables on the battery ends are not loose.
changed the clips to new one but still only tick tick.
<table id="post2672793" class="tborder" align="center" border="0" cellpadding="6" cellspacing="0" width="100%"><tbody><tr valign="top"><td class="alt1" id="td_post_2672793" style="border-right: 1px solid rgb(199, 226, 240);">coming sound indicates the relay is operating correctly ,but there might be a chance it is not receiving proper voltage due to lose connections at battery side
1.try replacing the battery with some other one
2.if problem persists check ur self for weak carbon brushes
but according to me ur battery might be culprit
</td> </tr> <tr> <td class="alt2" style="border-width: 0px 1px 1px; border-style: none solid solid; border-color: -moz-use-text-color rgb(199, 226, 240) rgb(199, 226, 240);">
</td> <td class="alt1" style="border-width: 0px 1px 1px 0px; border-style: none solid solid none; border-color: -moz-use-text-color rgb(199, 226, 240) rgb(199, 226, 240) -moz-use-text-color;" align="right">
</td></tr></tbody></table>
1-will do it and check
2- Recently installed new genuine carbon brushes hardly used self 20 times after
installing new carbon.
@ALL thankx everyone for your quick replies
