Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Like Tree5Likes
Thread: Tapit Adjustment in Chonda?
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    Exclamation Tapit Adjustment in Chonda?
    Yesterday for the first time i go to the Mechanic for Chonda Tuning and he adjust the Tapit Without using the Strip which used to set the Gape between Cam Tapit and Value .. i ask y u did not use the Strip he said Chonda did not need that coz if i use it the Tick Tick Sound is gona come from ur Head thats y all the Mechanics did not use Strip for This? and right now i just Confused is this true ... Please Help Me
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    this is called quackery..
    the gap is kept at .05mm for both exhaust and inlet,,so its a vvery small figure and one can easily mis it if proper feeler gauge is not used,,
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    many mechanics in 70's - 80's used to do this when i was a kid. he needs to be an expert on engine.
    gap adjustment strip is highly recomended but those who dont listen, will not listen, even if you ban yr head with wall. .
    better is yu ask before what eqpt he has to do the task before opening the engine
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    ^^ correct,,
    itna small gap andaza sa achieve nahi hotha,,
    take it this way one cm contains 10mm ,, and the gap is .05mm ,, in other words break a cm into 20 parts,, and the length of one part is what ur chonda needs,,
    improper valve clearance can cause a lot of damages ,, so u better next time ask a mechanic to use it or change a mechanic,, there settingas are some times accurate but most of the times i noted those to be wrong,, they were almost more then .08mm sometimes .1mm ,, hope this helps,
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    Today i call the Habib Head Office in Karachi for the same problem they give me the Phone no of Authorized Dealer in Multan and he also do the same thing he said its the original setting of Habib that there is no Gap needed between Values and Tapit ... now where to go ...
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    hilarious reply,,
    cant u do it ur self ?
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    i dont have a good camera else i would have made a video of it,,
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    Sorry for interruption but i want to ask h3llzang3l that is there any difference in performance of the bike before and after Tuning ??
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Had hogyi yar. . . .
    There is no Gap needed b\w valves & Tappits
    I Am the Feel
    I Am The Yamaha!
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    @talhabinomar
    Haan yaar Phly acceleration achi thi abhi ak dam nahi uti hai tora Zoor lagati hai per top speed teek hai ...
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    adjust ur clutch,, hope it will give u some good response,,
  12. #12
    speedster_101's Avatar
    Sep 2005
    3,447
    54 Post(s)
    What is Chonda?
    "The more we sweat in peace, the less we bleed in war"
  13. #13
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    ^^ google it,, or wiki it,,
    in short a chinese clone of honda engine,,
    yani honda k motorcycle ki chayni copy,,
  14. #14
    Sep 2005
    3,447
    54 Post(s)
    Chinese Honda = Chonda
    Haha, ok.
  15. #15
    May 2011
    26
    2,469
    38 Post(s)
    Check your Clutch + Plates
  16. #16
    asjdsm's Avatar
    Apr 2009
    30
    3,467
    57 Post(s)
    3 Thread(s)
    ^^ he is having new bike no need to check plates so early and open the case,,,
    however all that is needed i to fiddle with clutch,,it wll b ok,,
  17. #17
    h3llzang3l's Avatar
    Jan 2011
    Multan
    76
    W8 i should do with the Clutch ... Loose it or Tight it ...
  18. #18
    May 2011
    26
    2,469
    38 Post(s)
    Well i have this problem but i went to the mechanic told him the problem and he adjusted the clutch. I did not notice that what he is doing but after that no problem
  19. #19
    AsadGhumman's Avatar
    Jan 2009
    32
    2,377
    28 Post(s)
    19 Thread(s)
    Yaar ye "Chonda" hai kia??? many people use this word here
  20. #20
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Quote Originally Posted by AsadGhumman View Post
    Quote Originally Posted by speedster_101 View Post
    Haha, ok.
    I Am the Feel
    I Am The Yamaha!
