My CD 70 has oil leakage problem. If the bike keeps on standing for 2-3 days you can clearly see the engine oil on the ground (caltex has distinct wine red colour). The oil is leaking from the bolt underneath (used for draining the oil), already tried to tighten it but the problem persists. What can possibly be the problem ?
Use a rubber washer on oil drain nut.
Doesn't it come installed from the factory ?
I hoping u did not tried to fill 1 liter can of oil in the tiny crankcase by urself?
No, i use this 0.7L pack and i get it changed when i get tuning done from (HONDA).
Can it be something to do with the seals ?
Seals are Leak. Change them usually they are called GEN KIT available at every Spare Parts Shops and any good mechanic will do it for you.
Saw you bike in the ur rides section.
Seals getting leaked this early, and people here keep on arguing about how good the Quality of HONDA is.
