hi
my bikes battery is not giving any good result,, i have thoug neglected it quite sme time,, quite a few times i had not checked the electrolyte level,,and result it was way way low,, also quite a few times i overfiled it ,, so result is a poor response these days,,
on idle bikes head light is very weak,, though i placed new stanley bulb,, janyaan balp,,,, still no good,,
so what should i do?
i have seen that new batteries ome empty with the acid and water in seperate containers and they are poured in when they r to be installed,,can i empty it and refill it? or is it done this way?
is there anything good that can be done to revieve this battery ?
and what r my replacement options? if new is needed which brand should i get? is thetre some other better option?
also whats the function of battery in these bikes (70cc) ? i mean headlight tho is say chalthi nahi,, srf bike off but ignition switch on positioin ma isharay and horn hi chaltha hay is sa which is not a good use of it,,
