Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree7Likes
Thread: 70 road grip
    aqibabbas's Avatar
    Aug 2009
    South
    1,930
    Default 70 road grip
    Is there any possible way that can increase the road grip and braking of 70cc bike?
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    I think we can increase weight in some ways but i am not sure about them. My guess is major reason of bike weight is due to bike frame/chassis weight. For example my Firebird 70 have 90KG weight which makes it more heavy then other 70cc bikes. more weight increase better road grips. So you need to add some more weight in your bike.
    For better brakes i think it is not possible with drum brakes however installing discs brake will add more control and braking.
    31.5497 N, 74.3436 E
    aqibabbas's Avatar
    Aug 2009
    South
    1,930
    wider tyres lag saktay hain 70 mai?
    Quote Originally Posted by Juste View Post
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    wider ka tho nahi patha but u can instal one with 6 ply rating instead of default 4 ,, it will help a bit,, but 70 has everything optimized,, little room for improvemnent until u go drastic,,
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    braking can b improved by hvng cut brake shoes u can hv better road grip by havng wider tyre as 250-17 mein DIAMOND ka THUNDER ara hai
    Here is the link of Diamond tyre i m using it on my 70 and very much satisfied wd dis
    Diamond Tyres Ltd.
    My Vehicle is an ALL MOTOR. Seriously, Who needs a turbo when u have a Stupidly Quick Naturally Aspirated Motor???? Real Motors don't need Forced Induction. EG for life
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    ^^ default of my dhoom 70 r
    front
    2.25 - 17 4 PR
    rear
    2.5 - 17 4PR
    but mine now is rear 2,5 - 17 6 PR
    so fc br i think thats no wider then stock? m i correct?
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    wider Tyre means more contact to road it will increase the grip but as well as fuel consumption also
    if u r serious about road grip and brakes
    then just install the disk brake in front wheels
    and 2nd increase the wheel base of your bike for grip
    by increasing the frame head angle or by increasing the length of swing-arm
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Install 2.75-17, 6ply rating Tyre with some very good brake shoe and u wont have to complain again!
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by Automotorsport_Lover View Post
    is it available?
    and is it possible to use it with stock rim? without having any issue,,
    i mean tyre would be motre wide but rim would b same small...would the blend together well?ya na ho rim tyre ka andar ghusss jaya?
    talhabinomar's Avatar
    May 2011
    26
    2,471
    38 Post(s)
    Please do not do any alteration. Go for the 6PR Tyre in the design of Honda Deluxe. it has excellent Road Grip
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by asjdsm View Post
    is it available?
    it should ork w/o trouble... have seen people put broader tires in Junoon... That are of CG125.. But the rim size should be same. Tire pressure should be kept same or a little higher...
    The bike wont remain nimble in handling, but tire shudnt do any trouble as in case of cars.
    jumping to a very broader tire might not fit in the same rim, but jumping one size i.e. 0.25 should work w/o changing the rim.
    Asked it from Honda authorised mechanic once... he said its possible.
    Any tire wala should be consulted before the experiment. havent done maslf.. its just my logical guess.
  12. #12
    aqibabbas's Avatar
    Aug 2009
    South
    1,930
    link is not working.
    How much difference in width of stock and diamond tyre that u r using?
    can u plz post pic of ur tyre and bike?
    thx
    Quote Originally Posted by FC View Post
    Diamond Tyres Ltd. 70 road grip - wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH5BAEAAG4ALAAAAAARABAAAAfNgG6Cbg4sJwSIiYgag4RGPUAHkpMHMWsSg2kjSTwInp8ISi5PghY1bWwDqqurR0NuORxdUhAAAFclPrYREBAtbmMiVQ8Pth0vtlw4xGdLQmgK0bYYWAA7HtEKN2pmNgbftuFO399UVk0J6QnhAGA0IRfpWR8oWgz34WRbABEb9yZuCAhYQNCWigViItgiGMUNERkkGjQAkAFJAxhebEkMIgHEx0BQoocGYDCIAkgoAhYyZJligqDHMyY8KWAzZsFVkwxGTNIBXbsJrgJBAA7
  13. #13
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @all
    from this u can imagine how much this is wider and has dimensions like sports grip tyres
    70 road grip -373019
  14. #14
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    https://www.pakwheels.com/forums/bik...0-model-2012-a
    Install this tyre it will increase grip little bit
    you will enjoy your ride and feel solid bike
  15. #15
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Hello Friends Kindly Help I have a question kindly
    Suggest me which is good Mobil Oil for bike
    Caltex Havoline
    Zic
    Zipex
    Shell
    Castrol
  16. #16
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    abhi tak mjhy khud kuch andaza ni ho paya sab aik jaisy lagty hain but i use Caltex or Castrol
  17. #17
    Juste's Avatar
    Aug 2011
    1,983
    23 Post(s)
    Quote Originally Posted by amjad635 View Post
    Caltex Havoline
    Zic
    Zipex
    Shell
    Castrol
    Here on pakwheels and out of pakwheels from different peoples everyone vote for Caltex Havoline, even our mechanic suggested to use it. I bought it around 3 days ago for my old 70cc bike cost was Rs.250 (for 70cc bike less then liter bottle)
  18. #18
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i purchased havoline in 380
    but this time i have purchased zic
    as shopkeeper was admiring it too much
    and this is little cheaper 350
  19. #19
    aqibabbas's Avatar
    Aug 2009
    South
    1,930
    zic is not much good.
    shopkeeper was admiring because zic company offered him a decent commision/sale to increase there sales
  20. #20
    aqibabbas's Avatar
    Aug 2009
    South
    1,930
    congr8s on ur new purchased
