Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Maddriver
Thread: Philips Hid Conversion Kit. can i install it in CG-125?
    Maddriver's Avatar
    Jan 2008
    Hyderabad
    25
    1,334
    16 Post(s)
    Default Philips Hid Conversion Kit. can i install it in CG-125?
    Asalam Alaikum
    This is a pair of HID COnversion kit suggested by a friend. he is using it in his car. Can i install it in honda Cg-125 bike. Should i need to change the battery.. How can get both points(Yellow light = low beam, HID/Xenon on high beams. should i need to change the lights. or do i have to modify the head lamp..
    will it give good results..
    want to have
    • Clear Vision. as i usually travel at night
    • High beam on HIDs and low beam on normal yellow light
    • Good focused light. as i have seen hids on many bikes but they are not focused. the beam is so much dispersed.
    • a light so intense that my bike gets noticed by everyone... to leave a cool impression
    Philips Hid Conversion Kit can i install it in CG-125? -408840 Philips Hid Conversion Kit can i install it in CG-125? -408841 Philips Hid Conversion Kit can i install it in CG-125? -408842 Philips Hid Conversion Kit can i install it in CG-125? -408843
    have Some Questions Regarding installation of Hid
    1.Can i install this kit?
    2. what things i have to buy?
    3. i know i have to change the battery which one should i get.
    4. white type of bulb is commonly used in honda 125. for example h1, h2, h4 h8 etc.
    do i need to change the lamp is it neccesary?
    5.FOr r1 Why did you change the head lamp? couldnt you install hid bulbs on the stock lamp. because i think aftermarket lamp has not good plastic so the beam is blurry. and also the focusing chrome is not up to the mark?
    Stock Lamp
    Philips Hid Conversion Kit can i install it in CG-125? -408887
    aftermarket
    Philips Hid Conversion Kit can i install it in CG-125? -408888
    Bikes don't leak OIL.. They mark their Territory.. Think BIKE think BIKER
    murtazee's Avatar
    May 2009
    38
    1,402
    3 Post(s)
    nice hids
    let the expets come
    The time you enjoy wasting is not wasted time.
    talhabinomar's Avatar
    May 2011
    26
    2,471
    38 Post(s)
    Yes you can install this in your bike.
    Things Required
    1. HID Kit
    2. Battery 10 Amperes (Dry one will be preferred)
    3. Lamp which have Steel Back
    4. A good Electrician who knows his work
    Maddriver's Avatar
    Jan 2008
    Hyderabad
    25
    1,334
    16 Post(s)
    Bump.........!!!!!!!!!!!
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Plastic beam will melt if you use it with HID.. use metal beam further check your inbox.
    Dream is not that which you see while sleeping it is something that does not let you sleep.
