Technical Specs are as below;
Length, Width and Height: L=2045mm W=680mm H=1120mm
Wheel Balance: 1265mm
Minimum Ground Balance:165mm
Dry Weight: 120 kg
Height from Seat: 785mm
Fuel Tank: 12 Litre
Engine Type: 4 Stroke, Single Cylinder, Air cold Model LC 157 FMI
BorXStroke: 49.5mm X 56.5mm
Displacement: 124cc
Max. Power: 8.5 NM/ 7500 RPM/ MIN
Compression Ratio: 9.0:1
Clutch: Dry Multi Plates
Start: Kick/Self
Battery: 12N/2.5-3C
Ignition: C.D.I
Transmission: 5 Gears
Gear Ratio
1st Gear 2.769
2nd Gear 1.882
3rd Gear 1.400
4th Gear 1.130
Maximum Speed: 90 Km/hrs
Fuel Usage: 1.9 Ltr/ 100Km
Engine Oil Grade: SAE 20W-50
Tapit Clearance: Inlet Valve 0.05-0.08
Exhaaust Valve 0.05-0.08
Front Brake Free Play: 10-To-20mm
Rear Brake Free Play: 15-To-25mm
Spark Plug: 8 DRTC
Drive Chain: 10-To-20mm
Tyre Size:
Front: 2.75-18
Rear: 3.25-18
Frame: Strong Backbone Type
Although I have pasted all the technical stuff but I am not sure if its good or bad, please give ur reviews.
Thanks
