Results 1 to 16 of 16
Like Tree4Likes
  • 1 Post By usman505
  • 1 Post By asad_racer120
  • 1 Post By blackzero_01
  • 1 Post By asjdsm
Thread: 125 deluxe knocking problem
    arslan.asghar1's Avatar
    Jun 2013
    Rawalpindi
    28
    96
    Default 125 deluxe knocking problem
    i need ur help guyz ...
    my deluxe starts knocking after 10k rpm ... (knocking is same as we give full acceleretor with OPEN CHOKE )
    and it does when the engine is hot (like after traveling 15 kms ...)
    i have changed plug to autolite irridium plug
    got it tuned
    got carburator cleaned
    but still the problem exisists
    kindly advise me or tell me the possible reasons for this
    asad_racer120's Avatar
    May 2010
    Mehar
    24
    308
    4 Post(s)
    bro have major problem sell the bike
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    After 10k ? is an engine redline what are you trying to do explode the engine... but joking apart I know the problem ..
    Quote Originally Posted by arslan.asghar1 View Post
    got it tuned
    :-D
    Quote Originally Posted by asad_racer120 View Post
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    fuel adjustment is different the normal plugs when using with iridium and u need high conducting wire (and or not mandatory but have seen in some cases high voltage ignition with wiring upgrade in some cases) or it will keep on choking and knocking...
    lastly I hope you didnt bought it from Makhdoom because there plugs have that problem. men mehnga lay leta hon xtreme walon say mager unsay nahi leta atleast ye pta hota hai k it will work..
    -Hope it helps.
    usman505's Avatar
    Apr 2012
    Rawalpindi
    22
    301
    3 Post(s)
    got it tuned
    have u checked the air filter ? and air filter housing?
    does it gives black smoke(black soot) on accelerating?
    if not than do check the little filter in the fuel on/off knobe
    (just below the tank)
    May 2010
    Mehar
    24
    308
    4 Post(s)
    log bike ki care nahi karty jab dam torti hay to help help help
    blackzero_01's Avatar
    Oct 2010
    Dubai
    160
    got it tuned
    1. Tappets Adjustment for high RPM
    2. Spark Plug
    3. Fuel Quality
    Sent from my GT-I9500 using PW Forums mobile app
    ~~ Four wheels move the body. Two wheels move the soul.. ~~
    [Black Zero]
    Jun 2013
    Rawalpindi
    28
    96
    thanx alot for ur help bro..
    i just ment when i give some accleration then it starts knocking ... i dont think its wire problem because it was doing the same with ngk plug thats why i switched to irridium... and i bought this plug from a guy in faisalabad from chiltan motors he is disbributing these
    Quote Originally Posted by vickytulla View Post
    -Hope it helps.
    Jun 2013
    Rawalpindi
    28
    96
    i will chek the tapet adjustment
    plug is ok because same problem was with my older plug also
    and fuel i usualy use mix of hi octane and super
    Quote Originally Posted by blackzero_01 View Post
    2. Spark Plug
    3. Fuel Quality
    Jun 2013
    Rawalpindi
    28
    96
    bro i will aprtiate if u come up with some solutions instead of tonts
    thanx and no offence
    Jun 2013
    Rawalpindi
    28
    96
    bro i dont feel any black smoke out of exaust and kindly explain something about air filter housing
    Quote Originally Posted by usman505 View Post
  12. #12
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    make sure that when u open the throttle fully .. the slide inside carb is lifted fully and the venture/bore of carb is fully open ..
    try opening the race full and try to feel the slide going up through your finger if seeing is difficult or try to use some sort of mirror .
    also make sure that when the carb is fitted it holes are flush with those in the head .. kabi kabar ya holes perfectly match nai hotha .. jis ki waja sa rpm tho barhthi ha but fuel nai andar jatha ..
  13. #13
    Jun 2013
    Rawalpindi
    28
    96
    thanx bro ... i will chek it soon
    Quote Originally Posted by asjdsm View Post
  14. #14
    Jun 2013
    Rawalpindi
    28
    96
    @ALL brothers thanx for ur advices and thanx for ur time
    i spotted the reason for this problem that was a chor(anti theft) switch which i got installed and its connections were done from one of the wires from cdi unit those connections were loose and switch was also not working properly so i connected the wire directly without any switch and now there is no knocking..
  15. #15
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    LOL khoda pahar or nikla choha wo bhi mara howa..
    By the wayif you do instal the high voltage ignition and high volt cable bike performance will be improved so as the fuel economy.
  16. #16
    Jun 2013
    Rawalpindi
    28
    96
    yeh bro i have these things in my mind ... i will do these as soon as i have some budget
