bahut ala...yeh tu car wali treatment kar di bike par ap na....
Very well job done by you. It shows it's your passion to keep bike neat and clean keep it up buddy.
Thanks bro!! There is NO harm in claying the bike/car after every 4 - 5 months.. Yes! Its compound that should not be used much often..Otherwise Wax after every 2 weeks / Clay + Polishing + Sealant after every 6 months..
Yups bro.. already yeh bike first time compound ki gai hai after 6 years of its existance.. I,ve advised my cousin to wax it often like after every 2 weeks or at least Once each month.. If he acts upon my advice then there would be no need to compound again even after 2 years. I,ve advised him to use Dodo Juice Purple Haze Natural Wax.
which DA polisher do you have?
Thanks bro... Lol @ car wali treatment.. Bike ko bhi car hi samajhna chahiay hai.. My cousin always kept this bike nicely cleaned all the time but due to the dry dusting he does, there were thousands of swirl mark and light scratches.. I,ve guided him proper way to wash and dry the bike. If he continues the proper way then INSHALLAH this bike would maintain its glory..
mashAllah nicely maintained ride .. just need a new seat cover and bar ends
Sent from Mars using Telegraph
Here comes my 2010 CG 125. 10k driven so far. Detailing done a couple of weeks back and the results were superb.
Used the following items.
1) Turtle Compound2) Turtle Scratch Out3) Shinex Carnauba Wax
Sent from my A60 using PW Forums mobile app
@shamail_haider
Good Work bro.. But the Turtle compound didnt clear out the swirls on your tank and not even did scratch out do anything about them. As you can see in the picture pasted below. In order to remove these swirls marks (Micro Scratches) you first need a Good compound polish and a Polisher. These can also be removed by hand but with effort and power and by applying equal downward pressure on whole surface. Hence a polisher is best for this job. 2ndly after doing compound you MUST polish the surface with a good Polish and you need to thoroughly work the polish in circular motions and then remove the remaining residue. After Polishing comes the part of WAX !! . Wax would then protect the hardwork by forming a protective layer on the surface and would add to the shine.
Compound = For Cutting the surface (Just Few Microns) and bringing new surfacePolishing = For bringing depth and shine to the surfaceWax = To protect and Shine
Swrils present on your bike tank :
@omarabdullah022
DODO JUICE BUFF DADDY DAS-6.
Recently purchased. First time issi bike par use kia hai .
MashAllah!That is one nice machine! Keep up the good work!
mind sharing the price tag bro ?
@raza115
Bought it for 21,000/-Rs without pads.. Pads are to be bought separately for 1800/-Res each pad..
3 different pads are used.. 1 for Compound 1 for Polishing 1 for selant & wax
Thank you
How to remove these stains from petrol tank cap. These stains are after removing the blue sticker that's usually on new bikes.
Apply formula's Scratch out and leave it for 2min..Then rub cloth hardly..It will be removed.
I used to get max 110km/hr
Thank you bro for such a guidance in detail. Yes, I failed to remove the deep swirls and I'm going to use the polisher and some other compound with a real hard effort whenever I'll have a long weekend because "sardi mein aisay kaam krnay ka dil nahi kerta"
Any other solution apart from buying scratch out.
IMO scratch out would be abrasive and induct scracthes on the chrome part.
