I saw TRM and used for my CG as an engine oil. senior members kindly guide me that which oil shouls I use for my CG ? It would be a great favour.
no trm is a very thick oil
trm should be used in cg if you have no piston ring as it is very thick oil
How many kilometers your CG driven until now?
Use Zic or Caltex
Caltex is best to use.
i have driven almost 700 kms as i bought it in used condition
How many KM in total its driven ?
Caltex havolene deposit shield 20w-50
Sent from my LT29i using PW Forums mobile app
havoline will serve the purpose. change at 1000km interval
almost 22000 kms as it was purchased in the end of 2011.
moreover meri bike full throttle k bad jb race choro aur phir race do tw ajeeb sa patakha type sound deti hai silencer se , E2 b nai hai phir b ye patakha sound , isnt it dangerous for piston ?
Yes it's dangerous ..get a bigger CDI unit
Sent from my beloved iPhone 5 using Tapatalk
20w40/50 is the recommended grade..I would suggest liqui moly racing 4t 20w50
dear sir asalam o alaikum if you are from khi, then go to the fuchs (hascol) pump which is held on main shahrae faisal. there you will found the better quality of engine oil specially for cg125 thats very good for it.
