Hi Friends i have hero 70 bike and the problem i am facing is that its causing me back ache since few days.(i believe)Now my question is will changing the seat to soft good quality foam do any good?I got shocks checked (rear front both) from 4 mechanics. All declared them perfect.Can we adjust the rear shock softness?If so how?What other steps can i take to make the ride more comfortable and soft?Any help will be highly appreciated.
Is your bike seat height is more? do you feel you are leaning to grab handle?
yes they are related .. .i swaped my bike seat but new is new seat is not good.though better then original ..
will play with old seat .. seat wala raised the front of seat wharease he should have rubed some material from the middle ..
making seat lower than fuel tank and handle can eliminate this problem
Seat honda 70 ki dlwaoo
Mirza
post a pic of your bike
U cant solve this problem. Hard suspension and bad riding posture is the reason.
Riding posture is not the issue I believe.As i can feel the seat quite hard.....!!I sit straight on the bike and posture is normal.Suspension if hard, can it be softened.?
seat is lower then handle of course however its aligned with the fuel tanks end curve.
No i find the position of it quite normal and no i don't lean to grab handle.
So what do u recommend me to do?Can U suggest me any?
I checked honda 70 seat too they both are quite similar.They both are equally hard.
Posted.C and suggest plz
i can see your rear shocks are of bad Chinese quality they are very hard, install Honda 70'S rear shocks, ap ki seat bhi shaid pather ki bani hoi hai; Just kidding bro, need to find soft foam!
By lower I meant lower than its normal height, if you don't feel stress on shoulders while driving it then it should be normal. Tried adjusting handle? I have same issue but I feel I have to lean a bit to grab handle so will try lowering seat more.
there is a advanced technology called airhawk...google it inflatable motorcycle seat ...unfortunately for the price of one of those seats you can get a new chonda
brother i replaced the seat yesterday but observed very minute comfort difference.Now as per your suggestion i will replace rear shocks.What about front shocks?What should be the price of rear shocks.?
