Moto Guzzi Norge 1200 Specifications
Engine
Type 90° V-Twin, 4 stroke
Cooling system air cooled
Displacement 1,133 cc
Bore and stroke 95 x 80 mm
Compression ratio 9.6 : 1
Valve gear 2 overhead valves operated by light alloy push-rods and rockers; exhaust valve maximum lift: 106° B.T.D.C. of overlap inlet valve maximum lift: 104° A.T.D.C. of overlap
Maximum power over 65 KW (90 CV) at 7,500 rpm
Maximum torque over 95 Nm at 6,800 rpm
Fuel system Weber-Marelli electronic fuel injection with stepper motor control
Starting electric
Ignition inductive discharge, digitally controlled, electronic twin spark ignition
Exhaust system stainless steel, 2 in 1, with tree ways catalyser and Lambda probe oxygen sensor
Homologation Euro 3
