Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Like Tree5Likes
Thread: Suzuki GP 100
    2468's Avatar
    Apr 2008
    36
    3,508
    7 Post(s)
    3 Thread(s)
    Default Suzuki GP 100
    This bike was in production from early 1978 to sometime in the 1990's It was available in 3 versions.
    1) Disc brake wire wheeled sports version
    2) Later sports version with alloy wheels
    3) Later commuter version with drum brakes and wire wheels.
    Eariest bikes were 12bhp and 8500rpm, 50mm bore 50mm stroke, disc valve 2 stroke. Maximum speed in low 70s and 0-60 somewhere around 14 to 16 seconds.
    Later bikes were detuned to 11bhp
    They weighed just under 200 pounds and had 6 volt electrics.
    Comfort
    Good seating position and seat, however pillion foot rests on swinging arm.
    Electrics
    Horrible, 6 volt lights and points hidden behind a flywheel which were difficult to adjust.
    Ease of maintenance
    Pretty good 1/2 hour to swap a piston, brake pads easy to change. However points difficult to adjust as removal of flywheel is necessary.
    Reliabilty
    Good and bad, electrics were a problem but rest was quite good, needed a rebore after 10,000 miles - of being thrashed. Points were a bane all the time I had the bike, I hate points they are horrible and a maintenance nightmare - directly caused two holed pistons due to timing being out.
    It along with lots of bikes of that period tended to rust easilier than it should. - I had to rebuild the fork legs with epoxy resin in the pits and gaters fitted.
    Running costs
    Quite good 60-80mpg, cheap tyres, plugs needed regular changing, 2 stroke oil easy to put in every few 100 miles (I think a filling lasted about 500 miles), pistons were cheap at £6.50
    Handling
    Not bad, on par for the class, main problem was bouncy suspension.
    Brakes
    Best in class by a long way, first 100 with hydraulic front disc brake. Capable of outbraking most vehicles on the road.
    Performance
    Standard: Very good for the class - OK best - it was the fastest 100cc production bike all the time it was on sale, cruises on ordinary roads at the limit without being flat out, could break 70mph on the flat but was tiring to ride at that speed as you had to conserve your speed.
    Modified: Due to watching a race between Barry Sheen and Kenny Roberts I crashed on a tight right hand bend and cracked the exhaust, 3 months later I replaced it witha Micron exhaust, a bit noisy but greatly improved performance. I up geared (15 to 16 tooth front socket), rejetted (97.5 to 102.5 main jet), replugged (grade 8 to grade 9 NGK spark plug, porting played with.
    Genuine 80mph on the flat (still accelerating), 11-12 seconds 0-60, faster than any standard 125 including the Honda twin. This was 80mph at 9500rpm including up gearing - it would pull to 10,000rpm
    Conclusion
    great cheap first bike, easyish to maintain, fun to ride, easy to tune. It could be ridden as a go to work/school bike, or thrashed for fun without too much licence risk.
    Good points : Performance, brakes (if disc), cheap to run.
    Bad points : Electrics, fragile to rust.
    What would have made it a better bike?
    12v electrics, electronic ignition, better rear shocks, front fork leg gaters, some anti rust treatment on exposed areas
    Suzuki GP 100 -581501
  2. #21
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Quote Originally Posted by 4X800 View Post
    i think gp have five gears
    yes its 5speed
    its killer and belongs to gto,rx gang
    legend will revive soon
  3. #22
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by imranbhatti View Post
    @2468
    Bro it all depends on how the desigenr design the engine just for example New 1800 CC cars available in Pakistan ( Altis & Civic) produces ~125 BHP while on the other hand it is the same power produced by modern 600 CC bikes Like CBR, YZF, GSXR, & ZX. If two person have same hieght & Wieght then wud it necessary that they have same power in thier Muscles?
    CC is just capacity of combustion chamber u cant relate it directly to the engines out put power.
    Specifically The Suzuki GP 100 & Yamaha RX series Bikes uses Reed Valve on their intake system which is far better technology than Rotary plate suction valve which is commonly used in legacy 2T bikes by Yamaha, KAwasaki, SUZUKI. So due to better intake system, bit higher compression & relatively high RPM Engine design tends towards more out put as compare to ordinary engine of same CC.
    quite satisfying description
