PROJECT FOR SALE:
Chassis: Honda CD-175. Model 1977 (Khi Registered)
Engine: Yamaha SR250, 4 stroke SOHC, 20BHP.
Front End: Complete Honda CB400 front end. (Brake Caliper missing)
Fuel Tank: Honda CB400 fuel tank.
Work on Chassis:
Rust removal and repair. (High end Craftmanship, as good as original).
The down tube is moved forward to make space from the larger engine.
The bottom cradle is lowered to make space from the taller engine and give it a low rider look.
All New engine foundations. One at the front (bushed), one at the back, and one at the top.
The engine sits absolutely straight when mounted and it not tilted towards the front at all. (Easier said than done).
The Front sprocket and rear sprocket are perfectly aligned together. (Tested)
The frame symmetry is perfect, very keenly observed, measured and ensured.
No nasty weld marks, aesthetics is important. The best alteration is the one u cant spot.
Inbox your offers.
