Results 1 to 15 of 15
Like Tree6Likes
  • 1 Post By arsalankhan321
  • 1 Post By saboor73
  • 1 Post By amjad635
  • 2 Post By Chaudhary007
Thread: my bike engine generates too much heat
    naumananjum's Avatar
    Aug 2007
    28
    261
    3 Post(s)
    Default my bike engine generates too much heat
    aoa my honda pridor 2200 km old engine gets hot..first i thought that this is due ti new engine and season was cold so no tension but now engine is not that much new...also weather is hot...every time i drive bike i feel heat on my feet and even the black plastic box gets hot... i fear that someday it might flash the fuel tank。 please suggest what to do...any good mechanic on pindi?
    Sent from my 2014813 using PW Forums mobile app
    arsalankhan321's Avatar
    Sep 2013
    18
    211
    4 Post(s)
    First check the silencer .If it is clogged it cause the engine to over heat. There are many other causes also.
    Sent from my SCH-I535 using Tapatalk
    Aug 2007
    28
    261
    3 Post(s)
    Quote Originally Posted by arsalankhan321 View Post
    ok thx i will please tell other causes as well
    Sep 2013
    18
    211
    4 Post(s)
    Quote Originally Posted by naumananjum View Post
    @saboor73. Tell him more causes.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bad clutch
    Lean fuel mixture
    Unwanted drag (brake etc)
    Bad oil pump
    Expired oil
    Etc
    Can cause bike engine to over heat
  6. 22-05-2016, 02:03 PM
    Senior PakWheeler
  7. #6
    Aug 2007
    28
    261
    3 Post(s)
    Quote Originally Posted by saboor73 View Post
    Bad clutch
    Lean fuel mixture
    Bad oil pump
    Expired oil
    Etc
    expired oil and unwanted drag are surely not the reason...how can i verify the other mentioned factors??
  8. #7
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bad clutch can be verified by riding if clutch feels sticky its bad
    Lean mixture can be checked by spark plug color start bike warm it up give 3-4 sudden half throttle and remove spark plug it should be reddish if rusty adjust fuel mixture
    Open tappet cover and see if oil is reach tappets to ensure if oil pump is working
  9. #8
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    if motorcycle was tuned by an unexperience mechanic with just an bad adjustment
    air mixture screw in carburetor can lead to extra engine heat
    and these are very hot days feeling heat while riding motorcycle is not surprising
    so it might be just your wrong doubt for extra heat
  10. #9
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Unless you are feeling drastic decrease in performance or sluggishness.....feeling heat in the feet is not an indication that the bike is overheating.....
    If you ride like there's no tomorrow, there won't be.
  11. #10
    Aug 2007
    28
    261
    3 Post(s)
    thx bro i will check..
  12. #11
    Aug 2007
    28
    261
    3 Post(s)
    Quote Originally Posted by amjad635 View Post
    thx amjad bhai...what was your expereince when ur pridor was that much old..please also suggest me the ideal tyre pressure as i had changed the rear tyre with 3x18 service ... and please also tell is it ok to fill 0.7 ltr oil instead of 0.75?
  13. #12
    Aug 2007
    28
    261
    3 Post(s)
    Quote Originally Posted by Chaudhary007 View Post
    Alhamdulillah performance is good..thx for giving me releif 😊
  14. #13
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Fill the recommended quantity, Atlas Honda oil comes in proper quantity
    if you are using anyother engine oil than fill 700ml bottle and pour 50ml
    more to compete 750ml its just a little bit more needed
    keep 45 in rear and 30 at front
    which tyre have you installed the 3.00-18 or 90/90 deluxe one
  15. #14
    Aug 2007
    28
    261
    3 Post(s)
    3.0x18
  16. #15
    engr.omersharif's Avatar
    Feb 2015
    31
    259
    2 Post(s)
    You bet I can cook an egg on my engine.
    Sent from my SM-J700H using PW Forums mobile app
