Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By Hassan1991
  • 1 Post By Mirza967
  • 1 Post By umar1994
Thread: cg125 euro 2 tuck tuck sound help needed
    boris123's Avatar
    Apr 2015
    53
    Default cg125 euro 2 tuck tuck sound help needed
    aoa pakwheelers here i want help with little problem i am having with my cg125 euro2 2016 its giving like tuck tuck sound when i park it in house when engine is off its like tuck after every 5 mints and it goes after 20mints what is this issue its really weired which thing is causing this
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    Quote Originally Posted by boris123 View Post
    its normal.....infact its sign of good engine.....its due to engine parts contracting due to cooling after engine is turned off.
    umar1994's Avatar
    Aug 2015
    21
    118
    Quote Originally Posted by Mirza967 View Post
    how it relates to a good engine?
    Sent from my SM-N900 using PW Forums mobile app
    Hassan1991's Avatar
    Mar 2013
    20
    2,283
    38 Post(s)
    Quote Originally Posted by umar1994 View Post
    Good question.....weak engine will also heat's up and cool down in same way.
    The first step towards knowledge is to know that WE are IGNORANT
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    when sludge is build up in engine specially in valvetrain area then this sound rarely comes .......this tuk tuk sound comes from valve train region ..........when sludge is build up then contraction is not so rapid as sludge has covered it so then it doesnt come......the main cause for it is the two different types of metals in the rocker arm.....one is copper which is tappet part which strike valve stem other is iron body of rocker arm.....they contract at different rates so when they contract rapidly this sound come......but when they contract gradually due to sludge then this sound dont come.....if u want to observe it urself then when engine is hot open valve cover and pour 4 5 drops of engine oil on valve train......u will notice this sound..........try to remember action of bimetallic strip studied in primary grade science......same sound comes in it also.....when u heat it up and rapidly cool it by pouring water.....in engine case there is no water instead its oil which has accumulated in valve train.hope u understand.so in short a clean engine produce that sound more often.
    umar1994's Avatar
    Aug 2015
    21
    118
    good. the answer is convincing but its a sign of a clean engine not a strong engine. ho sakta hai banda oil time pe change krta ho but ultimately riding rough krta ho.
    boris123's Avatar
    Apr 2015
    53
    what does this mean then i got a weak engine ??how can i shut this sound off
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    yup........good engine i mean clean engine.
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    not weak engine......u got clean engine.
