Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 4 tip spark plug for santro
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    831
    5 Post(s)
    Default 4 tip spark plug for santro
    I need advise about which brand / model of 4tip spark plug can be used in santro club gv. as i have heard that it increases fuel economy as well as performance.
    The revolution is not an apple that falls when it is ripe. You have to make it fall.
    (Che Guevara)
  2. #21
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    i bought 3 bosch super 4 plugs for 1000rs from dubai autos!
  3. #22
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    got em from long time in my mehran well they make a lil difference but i got 8mm wires now on petrol my mehran goes mad and CNG wheel spin is noticeable effort less acceleration but i advise go for plug wires as well if u can find for santro 8mm will do or 10.2mm will also be good
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
    Hanjiii Kaa Storeey Eehh !
  4. #23
    Bhop's Avatar
    Dec 2006
    30
    17
    Jz bhai which plugs will u recommend for a toyota corolla gli(cng)..2007 model
  5. #24
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    as ek drifter said go for plug wires also then there will be a noticeable change! i installed performance plug wires with bosch super 4 !now my car gives me awesome mileage+nice acceleration on cng also!on petrol it becomes hell fast!
  6. #25
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    WHO told you in what university that multi tip plugs would increase HP or power, if you feel any difference, its probably because your old plugs were worse than dog poop. Using original plugs would give you the same power.
    multi tip plugs are used in engines that have high CR and a heavy ignition system (whose specs are more close to welding equipment) - and mostly are used for longevity
    I have a set of Bosch Platinum 4 plugs that were used in a MB engine for 50,000 kms - then in a Honda Accord engine for 100,000 kms - when I lost 1 plug I gave them to a freind who has a charade with a beefy ignition coil. still running good for 40,000 kms - in total they have performed good for 190,000 kms in different engines - only with high capacity ignition coils (the original Honda Accord carby ignition coil produces 22Kvolts).
    Using them with a weak system resulted in retarded timing and bogging
    the carby accord has been using NGK platinum single tip heat range 6 plugs for 100,000 kms now, no problems so far
    they did not increase power/hp or any torque - the car performs like original new specs, pulls strong and no bogging, noise, heat etc.
  7. #26
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    jz told us in pakwheels university!
  8. #27
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Do platinum or irradium plugs enhance over heating of a car?
    https://www.facebook.com/skillgrafik
  9. #28
    imrandahar's Avatar
    Jun 2005
    Sadiqabad
    34
    1,174
    2 Post(s)
    if u drive petrol than no dout irridium is best if ur car on cng than go for bosch 4 tip, its best im using it in my spectra working fine since 2 years its long lasting n cold plug. coz cng needs cold plugs
    ikd
  10. #29
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    831
    5 Post(s)
    @jz.
    i dont think that if i run car 60k kms on copper plug and ruined the engin. if so than what's the logic behind it. kindly explain for others informatio.
    (Che Guevara)
