Results 1 to 7 of 7
Thread: Urgent:Gear Box Noise fromSantro
    bux
    bux is offline
    bux's Avatar
    Apr 2006
    Wah cantt
    36
    31
    Default Urgent:Gear Box Noise fromSantro
    AOA to all Members
    I have Santro 2002, when the car crosses 45 Km/h a strange kind of noise (Goong in urdu) starts coming from Gear box which keeps on increasing as the car acclerates. I took the car to Mechanic, he added treatment oil(Thicker approx. 8 Liter) but the problem is not solved yet. Mechanic told me that this is the last resort, next to that will be replacement of Gear Box.
    I need the expert advice to get the problem fixed. I would also like to know the price of new and used gear box and the availability in ISL/RWP region.
    Best Regards
    Ehtisham
    2468's Avatar
    Apr 2008
    36
    3,508
    7 Post(s)
    3 Thread(s)
    Does that sound comes in only fifth gear or in others as well?
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    Make Sure Sound Is Not Of Gearbox thus bearing...
    When Gearbox Dies...It Starts To Making Grinding Noises And Synchro's Fail Make Grinding Noise When Shifting....
    Using Too Much Thick Gearoil(High Viscosity ) Can Cause Damage To Box
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    bux
    bux is offline
    bux's Avatar
    Apr 2006
    Wah cantt
    36
    31
    Quote Originally Posted by 2468 View Post
    Well the noise use to come in third gear after attaining the speed of 45km/h
    AdnanBuddy's Avatar
    Feb 2011
    44
    The kinda noise, refering ... it might b some wheel bearing .. so ensure tht gearbox is the thing that makes sound.....
    Horse_rider's Avatar
    Sep 2009
    30
    1,363
    3 Post(s)
    check your wheels bearings.
    현대 애인
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Pinion gears have wornout,You will have to dismantle gear box to replace the gears.
    Never loose hope in life,every step gives u something.
