Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By NiGhTShAdE
Thread: Spectra Electrical work
    waqasjaved86's Avatar
    Sep 2010
    22
    Default Spectra Electrical work
    Hi,
    Ignition system on my spectra is not working properly. Car started fine however i m unable to switch it off using key. I have to pull the battery terminal off in order to turn off.
    What could be the possible reason?? Please do let me know any good electrician/workshop of Spectra.
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    seems like the key switch is bad
    haters gonna hate, potatoes gonna potate
    Sep 2010
    22
    May be. Actually i just bought it 3 days back. Do u know any good workshop in Khi?
    ch_ahmed's Avatar
    Mar 2014
    214
    just change the iginatio/key switch from electrician and avoid practicing of removing battery terminal while car started it will be very harmful..........
    NiGhTShAdE's Avatar
    Nov 2011
    29
    918
    62 Post(s)
    Quote Originally Posted by waqasjaved86 View Post
    Hi,
    Seems ignition switch is bad, change it AND MOST IMPORTANTLY if you are able to turn off your car by pulling off the battery terminal then your cars's alternator is also not working....get it checked and repaired, DONT drive with bad alternator if you dont want your car to stop in middle of road with total dead battery...
    NiGhT ShAdE>>~
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    @capsat........
    Sep 2010
    22
    Yes, i was not using my car due to this problem. It is resolved now after changing fuse, relay and ignition wires was also melted.
    Sep 2010
    22
    This problem is temporary resolved. I need to see specialist electrician to properly check the car as there r some other electrical problems as well.
