Hi people, i am offering for sale HID Xenon Conversion kit. This kit is what you see on brand new cars like bmw and mercedes lights. On your normal cars, you have halogen lights which work off 55w and give poor vision where as the xenon lights runs off 35w and gives 4 times the vision compared to halogen. This kit lasts up to a lifetime and there is no need to ever change the light of your cars ever again. This product is very good and is highly needed especially in pakistan as visibility in at night is poor and these lights dont glare in oncoming traffics eyes.
H.I.D Conversion Kit can generally be installed into the car that uses conventional halogen bulb headlight and has several advantages over halogen bulbs:
More light output. A 35W HID light source produced up to 3 x the lumens at the light source when compared to a 55W halogen bulbs.
Greater visibility. The combination of more light output and whiter color make for better visibility in most night time driving conditions.
Longer Life. HID lamps will last, on the average over 7 times as long as halogen bulb. It is usually said a HID kit would last you a decade or even more.
Easy Conversion. HID Conversion Kit is simple and easy to substitute for standard halogen bulbs.
What is Xenon Light?
The xenon bulb is a micro-discharge bulb filled with a mixture of noble gases including xenon. The bulb has no filament , as is the case with a halogen bulb, but the light arc is created between two electrodes.
What was Xenon Light developed?
No less that 60% of all traffic accidents take place in poorly lit conditions, Therefore, lighting greatly contributes to road safety an comfort. It is a fact that the elderly required more light than the young (a person aged 60 requires up to ten times more light than a twenty year-old)
What are the advantages of Xenon Light?
The xenon bulb provides more than twice the amount of light of a halogen bulbs, while only consuming half the power (wattage). There fore, the driver can see more clearly, and the car has more power for other functions. Moreover, it is environmentally friendly, as less power means less fuel consumption.
The clear white light produced by the xenon bulb is similar to daylight. Research has shown that this enables drivers to concentrate better. Furthermore, this particular light color reflects the road markings an signs better that conventional lighting.
In practical terms, the life span of the bulb is equal to that of the car, which means that bulbs need only be replaced in exceptional cases.
HIGH BRIGHTNESS: Increasing brightness 300%
WHITE LIGHT/ BLUE TINT: Offering comfortable white light or the brighter blue tint
CONVENIENT INSTALL: Just need to install the HID into the original halogen place, make the blaster stable and attach the electrical lines. Not need to remove the original Automobile Parts.
SAFE: The HID system will cut off when the car meets an accident which will protect you safely
In 2002, the renowned market research organization Edmond conducted a survey among car drivers whose vehicles are fitted with xenon headlamps. Of those surveyed 64 % were high-mileage drivers who used their cars a lot, driving more than 12,000 miles annually. The results speak for themselves:
94% had a positive opinion of xenon light, above all brightness (42%) and general quality of illumination (35%) were quoted
-85% of all xenon users state that they are able to see better at night, in the case of the over-50s, this figure is even 90%
-83% of all xenon users would order xenon headlamps for their next car
-75% of all xenon users said that the wider illumination of the road provides a greater degree of safety for cyclists and pedestrians
-75% of all xenon users said that thanks to xenon light they are able to recognize obstructions on the road sooner
-69% of all xenon users would certainly recommend xenon light to other drivers for their next vehicle
-66% of all xenon users deliberately chose to equip their vehicles with this option in order to improve vision at night and in poor weather conditions
-64% of all xenon users believe xenon light to be so good that it should be standard on all vehicles
-61% of all xenon users feel safer with xenon light
for more info contact subs1_@hotmail.com
