My car is not starting it gives noise of tic tic tic instead of sulf,Never had aproblem like such before it was driving smooth till an hour before it was just parked an d all of this started any who can help?
Your help will be apprecated,
Awad
By the way car is Mehran 2006
One more thing it starts with dakha system.But was OK an hour ago.
I'm not a genius but i figure the battery is completely dead
maybe you can connect your battery with another battery by booster cable this will help you...thats wat i know...but if the battery is dead then u have to see a mechanic..
^agreed
Battery might be an issue, but get the starter motor checked first, and gt it serviced especially if the battery has not given you a problem before.
Check the following things step by step,
1 - Battery terminals and all electrical connection related to starting system.
2 - Check battery water and condition of battery.
3 - Check the alternator and fan belt .
4 - Check the stator motor (Self).
1 - Battery terminals and all electrical connection related to starting system.This was the problem the wire connecting to the battery was not conncted well enough.
Thnx
dear
get check these
1.self2.generator3.battery4.air filter5.fuses
Three problems here:
1-Some time carbon appeared on inside of battery jumpers. remove jumpers from battery terminals and clean them with hot water, also clean battery terminal with REGMAL. after that tight the jumpers on battery terminals.
2- U can check (SELF) with replacing another battery if it works fine then there is no problem in self. if not then there is an issue.
3- Batter dead.
He Solved It Already...!!
That Was A Loose Connection Issue.....!! Read Carefully...!!
Regards
ba
@SER_GTR
You just pulled the hand brake of "The Experts Express" :D:D
No Offense
My given three points can help anybody else bro, dont criticize pls.
