The tyre pressure sensor is located on the 'outside' surface of the rim (between the tyre and rim where the air is filled)
Check that the tyre pressures are correct, if they are you may have a dodgy pressure sensor.
I'm surprised such an old car has a tyre pressure monitoring system....
