MY CAR HAS COMPLETED 100000KMS WHAT THINGS ARE NOW TO BE CHANGED OR SERVICED ITS XLI
go to toyota ravi motors and they'll tell u what ever u need and have my suggestion always make sure to take your car to originals and get original parts if u want best of itbelieve me ive experienced a lot
If your car isn't eating mobil oil, then nothing wrong with its ring&piston. You need to get its fan belt & camshaft belt repalced. U need to chnage oil a bit early than you used to. Nothing more.
aqs29...."nothing wrong with its ring and piston"??
A corolla Xli engine is easily capable of exceeding 350000 kms and if taken care off properly.. it STILL would NOT use oil or WOULD NOT require out of the ordinary repairs
timlng belt and bearing mainlychange all other belts as well
Hashim bhai i think these toyota engines have timing chains..i stand to be corrected though
Yup its 6mm chain.... btw what's fan belt :S as somebody said above
Xli Egine have timing belt and S.E Saloon engine have timing chain, by the way how are u doing Akber @ 5555just use your car as you were using it ... in Xli's owners manuall its recommended to change the timing belt at 120,000kms
take it to toyota theyll recommend the best...mostly belts and awl need to b changed
