Assalam-o-Alikum
All PakWheelers
main jana chahta tha k coure main kitne ltr coolant dalta hai aur osaka coolant kaisa hai is mian kis ratio se water mix hota hai plz help me
Osaka is a shit coolant.. go for caltex... mix with 50-60 % water.., grt coolant
pora collent hi dal doo yaar it does'nt matter ...
I recommend u to use Toyota Long LIfe Coolant or Caltex will also be OK. OSAKA is just colored water. u can check at Toyota 3S for amount of Coolant for Coure
Yaar my friend imports coolant from somewhere, if you guys are in Karachi so you can easily get it from friends cng. It is the best coolant I have ever seen, its colour is orange.
caltex a bit expensive thn local sharbats but really works man! you will never have any problem i think u will reuire 2 litre and rest water fr ur cuore
can u ellaborate how to pour it in the radiator and the bottle do we have to clear off all the water of radiator or just add it in the bottle
Toyota long life coolant hi use karlou yar....pink color....
Yar saare sharbat lalukhet mein ban rahe hain yeh
I use,hmmm,unable to remind its name:(,get it from Shell pump stores & it comes in green can,made in USA,a bit expensive.Pour it as it is,no need of water.
Guys what about NASA Coolant isn't it good???
yeah it is good coz it makes ur car as cool as a shuttle:p
I have used 2 coolant so far.
Caltex and DK made in japan.
Caltex is for around 380 Rs and DK for 99 RS but DK is also very gud.
@Caprion_7,
I use Osaka Coolant in my Coure,No rust till now...............
Just put 2 liters coolant in your radiator and rest with water,And the Coolant Bottle with full Coolant.................Now You can get OSAKA Coolant in Green,Blue,Red,And Pink Colour.
which one are u using these days?? IS DK reliable??
Now a days i am using Caltex. Make sure there is no water leakage in ur car and put 2 bottles of Caltex coolant and you wont need to add water in ur car anymore
I got a old 86 Charade but its been 3 months water level is not dropped even with a/c.
DK is good it works same like caltex. But DK is 400ML and Caltex is close to 1 L.
from where to find DK coolant in RWP/ISB
brother are you on a mission to mis guide other people, first you said that injectors are ruined by CNG and single injector for santro costs 18k, now pouring in pure coolant without diluting it, do you happen to have a car of own or not, whatever its much better to hold your breath on something you dont know.
@postercheck this linkhttps://www.pakwheels.com/forums/oil-fuel-fluids-filters/151107-learning-coolant-fundamentals
There's quite a few discussions already on coolant brands and how to replace it - I would suggest you use the search function to keep it nice and non-repetitive here.
Also, there's a thing that comes with your vehicle known as a user's manual. Very useful if you want to know what the coolant capacity is for your car and what the recommended mixing ratio should be with water
go for caltex poisonorange color....
